Drag Racing Tech
th350 crossmember
Old Jan 16, 2009 | 04:50 PM
Taubr Unit's Avatar
Default th350 crossmember
im doin a th350 swap and need a crossmember. Anyone else but BMR make one? Or can i mod my stocker to work?
Old Jan 16, 2009 | 05:23 PM
Camaro396's Avatar
UMI has one also. UMI-2225-R we have sold a couple at our shop.
Old Jan 16, 2009 | 05:41 PM
tim99ws6's Avatar
I have a UMI one i need to get rid of. Its got the TA relocation on it too if you need that.
https://ls1tech.com/forums/lsx-parts...elocation.html
Old Jan 16, 2009 | 06:31 PM
9sec93's Avatar
i had the wolfe one on my camaro. it was pretty cheap and nice quality too.
Old Jan 16, 2009 | 06:45 PM
Camaro396's Avatar
Thats the one we used on my trans swap today. Nice piece!
Old Jan 16, 2009 | 06:56 PM
Taubr Unit's Avatar
i dont need one with a TA mount, mines mounted to the floor, thanks thou. Sucks these things are damn near $200! wtf
Old Jan 17, 2009 | 02:06 AM
95z28camaro's Avatar
Not that it matters since you dont need the torque arm, but i wasnt satisfied with my BMR. The torque arm mount hits the trans tunnel so i had to rig up a way to make the torque arm mount up and i was no fun at all! But ya if i remember right there is a way you can make the stocker work... just gonna have to do some searchin, i dont really remember what they said.
Old Jan 17, 2009 | 08:08 AM
UMI Performance's Avatar
Glad you guys like the product!
The stock 6-Speed crossmember will work with a TH400... it just needs a spacer on it. The TH350 is quite short, the only way to make the stocker work would be to weld a mount on it.
If you have any questions regarding our product I will be glad to help.
Thank you!
Ryan
Old Jan 17, 2009 | 08:52 AM
Taubr Unit's Avatar
well if it helps me ut, the trans has the 9'' tailshaft so the overall length is the same as a 4l60. And is what i dont get is i put a th350 in my '89 iroc when i blew up the 700r4 (same as a 4l60) and i didnt need to buy a crossmember.
Old Jan 17, 2009 | 08:57 AM
csjta2's Avatar
I modified a stocker to work with mine, been running it the last couple years.
Over the Holidays, BMR had a fantastic deal on them so I purchased one of theirs
I run a 6 inch tailshaft 350 or a powerglide
Old Jan 17, 2009 | 09:06 AM
xpndbl3's Avatar
You did need to buy the conversion kit from B&M or the like to mount it to your factory trans crossmember, I am running it in mine as well, it lowers and moves the trans mount back probably 2" or so.
Old Jan 17, 2009 | 09:12 AM
Camaro396's Avatar
Just the tailshaft is longer though. The mount is in the same place. But at least you get to use your stock D/S for now, unless you're having a nice C/M or C/F piece made.
Old Jan 17, 2009 | 11:51 AM
Taubr Unit's Avatar
yea i got a new CM drive shaft made, i needed one 2'' longer. Im gonna fab mine to work i think. I have everything to do it so i guess i can give that a try and if i dont like it ill pop for a new one. Well see when it comes down to it i guess
Old Jan 17, 2009 | 02:16 PM
joelster's Avatar
Taubr--My transmission shop used a Fitz-all kit that re-uses the factory 4L60E tail onto the back of the th350. There is a 2" spacer that goes between the th350 and the 4L tail. That way my speedo still works perfect and it bolts right up to the factory crossmember. Kills 2 birds with 1 stone.
EDIT: the stock driveshaft works when yuo do it this way.
Old Jan 17, 2009 | 02:22 PM
Taubr Unit's Avatar
well i needed a new DS anyways because of the 9''. Sound scool but i personially dont like using spacers or anything retrofitted, thats just me thou. Ill still look into it, thanks for the heads up
Old Jan 17, 2009 | 02:48 PM
joelster's Avatar
Here is the link for the kit:
http://www.teckpak-fitzall.com/teckf...ts/s-350-2.pdf
Old Jan 17, 2009 | 03:09 PM
9sec93's Avatar
here is the link for the wolfe. it is $149
http://www.wolferacecraft.com/detail.aspx?ID=223
Old Jan 17, 2009 | 03:22 PM
Taubr Unit's Avatar
cool Phil, too bad it isnt CM or even aluminum. If you know BBRC, they made a aluminum one, im trying to find it again. But if all else fails prob. go with that one. You want to come off that cheeta shifter yet?
Old Jan 17, 2009 | 03:44 PM
9sec93's Avatar
they do have a moly one too for $189. but for the extra $40 for such a small part i bet there isnt even a pound difference. and i will pm you about the shifter.
Old Jan 19, 2009 | 09:57 PM
Taubr Unit's Avatar
bump.... anyone know of anyone else that makes one? Id like it to be eaither CM or aluminum.
