Drag Racing Tech
moterplate question
Old Jan 16, 2009 | 11:25 PM
93_z28's Avatar
Default moterplate question
i have an lt1 in my car and a bmr crossmember.i want to put an ls1 in but dont want to by a new crossmember.can i just use a moter plate instead and keep the lt1 crossmember?its not for a street car.
Old Jan 16, 2009 | 11:36 PM
xpndbl3's Avatar
yes with a motorplate you can run whatever crossmember you want. you won't have stock motor mounts then
Old Jan 17, 2009 | 10:23 AM
Fast_94_Z's Avatar
check out burkhart chassis stuff he will hook you up with everything you need. if you want to avoid using a k-member with motor mounts your more then likely going to have to use a midplate setup as well. im doing a turbocharged bbc in my car but he can do you a motor plate midplate setup and front end kit. basically my front end kit has one of his k-members, a manual rack, upper and lower a arms, drop spindles, aerospace brakes, bumpsteer kit, afco shocks. you can get what you need but i optioned and got every single piece that i could. by the way this is all on an lt1 camaro.
Old Jan 17, 2009 | 11:57 AM
Steve Burger's Avatar
LS1TECH Sponsor
Front plates will work with a torque strap. We can set you up.
Old Jan 17, 2009 | 12:00 PM
93_z28's Avatar
cool,thanks for your replies
Old Jan 17, 2009 | 12:04 PM
93_z28's Avatar
i know ive seen moter plates on your site before,but i cant find them now.can you post a link plz
Old Jan 17, 2009 | 12:41 PM
LS1TECH Sponsor
Check Here. They are 199.00
http://www.burkhartchassis.com/steveberger.html
Old Jan 17, 2009 | 02:00 PM
DMH Fabrication's Avatar
You can cut the LT1 mounts off your k member to save some weight.
Madman also offers the motor plates.
http://www.madmanandcoracing.com/sho...page=2&sortby=
