Drag Racing Tech
m-6 to th350
Old Jan 21, 2009 | 06:48 PM
Tony 2000's Avatar
Default m-6 to th350
recently swapped out my m-6 for a futral th350 and a 3000 stahl. previous best was a 12.75 at 109.6 wondering now what i might expect at the track motor is all stock except for headers and a lid and i will be running e.t streets with a 3.42 gear any launch techniques are appreciated thanks
Old Jan 21, 2009 | 07:04 PM
joelster's Avatar
For launch techniques make sure you vary your rpm on a few different passes. At first I would leave it at an idle and then stomp on the gas to get it to flash at the green light. Do this a few times until it is consistently ETing. Then experiment with raising the launch rpm, ie: hold it at 2000rpm or so and then stomp on the gas at the green light. Again see where it ET's. Some cars like to be idled at the line, while others like to be hard against the converter on the line. Only one way to find out.
