Drag Racing Tech
???cutting metal...???
Old Jan 6, 2009 | 08:04 AM
nemss1's Avatar
Question ???cutting metal...???
im removing my inner fender metal, unibody support next to back seats and the airdam bracing below the radiator
besides all of the mounting tabs from removing crap, WHAT OTHER METALS CAN I REMOVE???
searched this and got some ideas. seeing if anyone can come up with stuff that i may not have found
weight reduction sticky didnt list everything metal to be cut
Old Jan 6, 2009 | 05:49 PM
studderin's Avatar
you can cut the bumper support/ fram horns off. 5-8#s a side depending on how much you get off and angle the cuts, or just stairt.
The front of the wheel wells
gut the inner door skins
Old Jan 6, 2009 | 07:33 PM
nemss1's Avatar
thanx for the input! anything else guys?
Old Jan 7, 2009 | 01:12 PM
Magnet's Avatar
what unibody support are you talking about? you can cut all your extra brackets and such also (back seat and seat belts etc)
Old Jan 7, 2009 | 08:00 PM
nemss1's Avatar
the support i was talking about is the bracing that is spotwelded next to the rear seat in the sail/qtr panel region
Old Jan 7, 2009 | 08:43 PM
wlsmoku's Avatar
rear seatbelt brackets
upper and lower mounts for rear seat
Old Jan 7, 2009 | 08:54 PM
nemss1's Avatar
yup removing the lower mounts. got one side done. finishing up tmro or the nxt day depending on the weather here
also removing the lower part of the radiator support/airdam bracket. almost finished with that
also removing all misc brackets
Old Jan 7, 2009 | 09:01 PM
wlsmoku's Avatar
even though they unbolt - theres the door bars. sounds like you got a good handle on all of the metal removal though
Old Jan 7, 2009 | 09:09 PM
nemss1's Avatar
yup, already have those out. everything i have let to remove either deals with cutting or drilling spot welds haha
Old Jan 7, 2009 | 09:11 PM
cbra-klla's Avatar
you drilling spot welds out or just cutting??
Old Jan 7, 2009 | 09:13 PM
nemss1's Avatar
drilling everything that is spot welded to the body and patching up the holes. cutting off the frame horns
Old Jan 7, 2009 | 09:47 PM
Taubr Unit's Avatar
click the link in my sig........
Old Jan 7, 2009 | 10:08 PM
nemss1's Avatar
thanx man! yup thats what i wanna do to mine. very informative link
Old Jan 8, 2009 | 08:54 AM
wlsmoku's Avatar
are you not keeping the factory wiring, wipers and a bolt on hood? I woulda mentioned that stuff, but I assumed you were keeping it.
looks like you got all the other stuff already...
Old Jan 8, 2009 | 01:04 PM
cbra-klla's Avatar
You welding the holes up or just filling then with something else??
Old Jan 8, 2009 | 06:02 PM
nemss1's Avatar
i already finished up the wiring. just pulled wires i didnt need. keeping wipers because this car will have very few trips on the road and keeping the stock ss hood
im welding the holes back up
Old Jan 8, 2009 | 08:11 PM
cbra-klla's Avatar
got all but 2 of mine removed today........drill and a pry bar are your best friends!!!
Old Jan 8, 2009 | 08:34 PM
nemss1's Avatar
yup! thats what ive been using. drill and prybar
so far, ive remove the lower rear seat supports, radiator/airdam bracket
nxt the inner fender metal, frame horns and all misc brackets for the heat shields and crossmember brace
keeping the t-top area. not cutting up my floorboard or sail speaker panels
anything else i may have missed??? (as far as extra metal)
cbra-klla's Avatar
i took the passenger side door panel off today to remove the door bars....what is the trick to get them out??
Old Jan 8, 2009 | 08:36 PM
nemss1's Avatar
i grinded the bolts from the back side of the bar and used a holesaw to the bottom corner of the doors to slide em out
