???cutting metal...???
The picture explains it all. I did it with a sawzaw in about 2 minutes a side. Then ground the edges smooth(safety first). The metal you will remove is double sided so be careful, and do not to take to much off.
I am going to work on the car tomorrow, i will take pictures of anything else i can think of that i have removed, big or small. Hope this helps guys
I would think my torque bracket on the rear end would hit before the tubes would hit.
I took off the rubber bumpers but have not removed the steel. After reading this thread I will be getting the saw and grinder out for sure.
N2
also do please post any other 'metals' u have cut frm your car
, but I really like the way your front fenders turned out. It is the cleanest Ive seen done. Mind if I ask what you used to cut them out? Or did you just take a angle grinder, and make it all pretty after the cuts??? Thanks *metal on the back of the car
*sail panel metal (interior)
*metal on inner fender towards firewall
i cut it with a angle grinder and ground it super close with the grinder wheel on the angle grinder. Took about 2 hours a side but it came out real nice, thanks
ill be definetly taking them off..thanks for the tip
