AFR 225cc Small Bore With 233/239 595/603 Cam
AFR 225 Small Bore With 233/239 595/603 Cam
I just installed my heads and cam (AFR 225 Small bore Milled to 62cc Heads-TSP 233/239 595/603 cam) im going this friday to get a dyno tune, i was curious as to what numbers i can expect from this setup i have full bolt-ons plus forged internals with Diamond pro flat top pistons, i do plan on doing more mods later but this is my starting point. What numbers do yall think i can lay down with this setup?
It says 427/391 in his sig.. Not very good for the mods he has, but I think those 225's are overkill with a 346cid engine and it could use a cam that is custom ground for the setup.. My street car put down more than that with just a cam. Definitely needs a Fast 90/90 setup if he doesn't have one..
