Trans & Rear gear help
My Cobra has an auto in...best thing Ive ever done to it imo. Anyways the gears are
1st - 2.84
2nd - 1.55
3rd - 1.00
Rear - 4.10s
tires - 28x10.5 et drags
car weighs 3450 w/ me, should be 3350 this year
at my current power level 465rwhp and tq, 1st gear is SHORT. like starting to tap the shifter at the 60 foot mark short. so my first thought is to drop a rear gear to 3.90s. now 1st will be a little longer but the rpm drop from 1 to 2 and 2 to 3 will be greater. it already drops from my 6400 shift point down to 5000 so this would bring it down to 4700ish.
my second thought is to change the trans gears. I only have one other option which is
1st - 2.40
2nd - 1.47
3rd - 1.00
now this looks good. gear changes owuld keep the rpms up more BUT....is the 2.40 gear going to be enough to get the car going with 3.90s? how about 3.73s?
I pull mid to high 1.4s out of the hole now with the 2.84/4.10 combo but feel I just blow right through my broad power band. what do you guys think? Im not sure what all of your trannies run for gears so maybe you can enlighten me on some of your setups/power. thanks a bunch
