Changing tire size ?
So I'm thinking of switching to a 27 inch tall Hoosier Quick Time Pro with a 9inch tread.. I'm thinking with the smaller section width the tires would fit the car better allowing lower drag bag pressure and more weight transfer.. With the longer roll out of the 27inch tire and the hopefully wider contact patch I feel the car will hook better..
Am I thinking backwards that a slightly narrower(mabe not in contact patch) but taller tire will hook better on a stick car leaving a 6K ?
MPH 123 in the 1/4 with 3.91 gears and about 6300 through the stripe
Ben
In the first pic you can see the line around the tire where tread starts to wear.. Past that to the outside, the tires are not worn down..
