Drag Racing Tech
2004 GTO ABS/Booster delete
Old Feb 7, 2009 | 09:25 AM
LSPerformance's Avatar
Default 2004 GTO ABS/Booster delete
Anyone know of a complete ABS delete kit for the 2004 GTO? - SJM doesn't make one, are the F body kits compatable other than the brake line lengths/shapes?
Also, anyone remove the power brake booster? - if so, is the master cylinder bolt pattern close to the pattern on the firewall?, or is there another master cylinder that is compatable?
Thanks
Old Feb 7, 2009 | 09:36 AM
JL ws-6's Avatar
Race your car!
IF the maser cyl will bolt up (not sure) just do your own lines, rip all the factory lines off and make them over yourself.
Old Feb 8, 2009 | 06:00 PM
SJM Manufacturing Inc's Avatar
We chose not to design them due to the location of the ABS block in relation to the master cylinder. New lines would be the way we'd setup the design.
Probably the best looking option would be to cut your stock lines fabbing a intermediate kit with fittings. (if you care about how it looks). Another option is to union off your stock lines without cutting them and just adding lines you form yourself...we can supply anything you'd need.
Let me know how you'd want to go about it and I will be more then happy to help.
Make sure you add a proportioning valve as well...we can supply them as well.
Call me on Monday if you need something.
