Drag Racing Tech
How to hook on 17" wheels
Old Feb 10, 2009 | 07:29 PM
TA1364's Avatar
Default How to hook on 17" wheels
I am thinking about getting a c5 and wondering if 17inch z06 wheels would hook. If I go with a vette I would do a 4000stall and bolt ons so I am looking at cutting around 1.5x short times. What needs to be done suspension/rearend wise to make this work? Is it even possible?
Old Feb 10, 2009 | 07:38 PM
JonCR96Z's Avatar
I don't have a Vette, but I have a few bolt-ons, 4000 stall, and 17" M/T drag radials and I have went a best of 1.55 60' and a few 1.56s.
Tires alone will probably get you some 1.5s in a Vette. Especially if you run 17x11s with 315 DRs.
Old Feb 10, 2009 | 09:04 PM
Photochop's Avatar
Its all in the converter, and making sure the tires hook. Suspension helps too...but you'll see the biggest difference in a well matched converter.
Old Feb 10, 2009 | 09:29 PM
TA1364's Avatar
Well I had a 4000stall in my trans am with 16" tire and et streets, it went 1.57. It chattered the tires a lot and hardly ever fully hooked. I know what converter will do it, I just dont want something that is going to be useless if it never hooks. Tires were only 255s tho. I was just thinking with less sidewall of a 17" wheel it will be worse.
Old Feb 10, 2009 | 10:22 PM
xpndbl3's Avatar
at the track there is really no reason not to run a 15" slick IMO.
Old Feb 10, 2009 | 10:55 PM
johnLs1camaro's Avatar
i agree, you should be fine with hooking the 17's.. buts it is all in how you work the converter!
Old Feb 10, 2009 | 11:02 PM
MATTREDSS's Avatar
My best 60' on mt 275s is 1.57 so far
Old Feb 11, 2009 | 02:14 AM
TA1364's Avatar
I am not putting drag wheels on a vette, not going to happen.
Old Feb 11, 2009 | 03:09 AM
PowerShift408's Avatar
Well it's not a Vette, but MightyMouse went 8.7x @ 160ish on 17'' wheels with 315/35/17 M/T ET streets.
Old Feb 11, 2009 | 08:14 AM
3DFORMULA's Avatar
Then why put a vette on a drag strip?
Old Feb 11, 2009 | 10:23 AM
TA1364's Avatar
Its mainly going to a street car this time around since the track is a lot farther away for me now.
Old Feb 11, 2009 | 02:32 PM
Photochop's Avatar
Might talk to the corvette guys to see what all suspension tweaks can be made to help hook. A hoosier or MT 17" radial can be made to hook quite well, but you may have to mess with the suspension more than you'd like for a successfully consistent launch.
Old Feb 11, 2009 | 03:13 PM
BlackScreaminMachine's Avatar
Internet Mechanic
PM Zturd, he runs fast in a vette, recently blew up the rear and did it on a 15" rim I beleive. the issue with a 17" rim is you will not have enough fender well to accomondate a taller side wall, and the side wall is what is going to give you that ability to hook.
Depending on how much power, and since it is an auto look for 17" drag radial, I think M/T makes one now.
Old Feb 11, 2009 | 04:12 PM
TA1364's Avatar
I know the issue with 17" wheel is going to less sidewall, thats why I made this thread to see what else can be done to help compensate for that.
Old Feb 12, 2009 | 11:28 AM
CodeRed2000SS's Avatar
M/T drag radial, should get you right where you need to be. there is really no need for a slick.
Old Feb 12, 2009 | 11:58 AM
JonCR96Z's Avatar
This guy is obviously in the know.
Old Feb 12, 2009 | 12:13 PM
nahasapeemapetalon's Avatar
How far do those things stick out?!
Old Feb 12, 2009 | 06:49 PM
3DFORMULA's Avatar
very minimal, about 1/4"
Old Feb 12, 2009 | 06:55 PM
3DFORMULA's Avatar
What I'm gonna do is is go with a hoosier 325/40 or 45. They have a 28" tire, which will provide more sidewall.
Old Feb 13, 2009 | 01:56 PM
TA1364's Avatar
Those 315s look huge, seems like that would slow the car down.
