WTF , Only .28 gain after mods.
any weight mods??
but usually 30hp would get you 3 tenths and 1.5 to 2mph roughly
everyone also thinks gears are gonna help alot, but really guys hardly see a tenth gain from them if that.. one reason i still have 3.23's
once you get a bigger stall and 60 ft better your mph should jump on up.. i just think you need roughly a 3200-3600stall now
good luck and try agian when the weather dips into the 50-low 60's and I bet you will see 112 traps
Last May it ran 12.40s all day at 110.00 with 58deg,30hum,30.18pres, DA 321, would that make a lose of time and mph. This is at the same dragway, all runs. Also I am going threw the traps at 5700rpm,is that to low ?
You should be going 2-3 mph faster now, I'd be looking for 112mph at least.
Or I could be looking at this the wrong way, maybe this cam would like less timing. And your latest pass?
13:1 + 29 degrees could be on the edge, you can always try adding fuel and seeing if the car picks up.
Same track and different DA can account for a huge amount of ET and MPH...I picked up 2 tenths with just the temp drop from 70ish to low 40s...
