Drag Racing Tech
Battery killswitch mounting...
Old Mar 1, 2009 | 10:25 AM
patriotformula's Avatar
Default Battery killswitch mounting...
Tried doing a search for setups, I'm pretty sure I've seen a killswitch thread before... Anyways couldn't find one, so post up pics of your kill switch mounting location and setup.
Also on a question of legality, NHRA states that you must have a bulkhead or divider between the driver and battery, would the stock rear panel (spare tire are) count as a "divider"
Old Mar 1, 2009 | 12:14 PM
yrlosing's Avatar
nhra states that it must be a toggle or push/pull switch on the back of the vehicle.
and it must be metal! no plastic handles allowed.
i have seen them mounted right in the center of taillight panel (next to the lock) and i have seen them mount the switch inside the car and then run the push/pull rod out the back through the bumper. ?? it's all in what looks good to you?
if your moving the battery to the back, just get a battery box! this is your mounting and your bulkhead. the battery just has to be sealed from spraying acid all over in a crash. but i would use a optima (gell cell) anyways.
Old Mar 1, 2009 | 12:59 PM
Not into the battery box look... I already have a bracket similar to the bmr one...
no pics guys?
Old Mar 1, 2009 | 02:24 PM
DanZ28's Avatar
Found a few with the search.
https://ls1tech.com/forums/drag-raci...shed-pics.html
https://ls1tech.com/forums/drag-raci...h-install.html
https://ls1tech.com/forums/drag-raci...h-mounted.html
Old Mar 1, 2009 | 06:32 PM
Thanks Dan... Gives me a few ideas...
Old Mar 1, 2009 | 10:23 PM
DanZ28's Avatar
Yeah, not much out there to look at.
Old Mar 2, 2009 | 06:23 AM
Photochop's Avatar
I'm in the same delima for switch mounting and trying to find ideas. I'm going to either mount mine to the right of the 'camaro' text on the tail panel (paint switch handle black - I have a rotary type switch - so its less noticeable against the black tailpanel), or mount it behind the license plate and remove the plate and install the handle to the switch when I'm at the track - and remove the switch **** when the plate goes back on. The tag won't sit completely flat, but with longer screws and 1/2" spacers no the tag screws it won't look too bad. Mines primarily a street car and I don't wanna have big obvious cues that theres more to it than that.
Old Mar 2, 2009 | 04:48 PM
Camaro396's Avatar
I used an on/off style switch.
I'm switching to an aluminum battery box.
Old Mar 3, 2009 | 10:18 PM
Black94Z28's Avatar
Pics of mine...
Old Mar 4, 2009 | 11:01 AM
Any pictures camaro 396 or black z of the switch mounted (in the trunk area).
Old Mar 4, 2009 | 11:07 AM
cbrrmike's Avatar
i have the bmr basket and flaming river switch in my t/a, when i go out later to brush the snow off ill snap a couple of pictures for you.
the switch is mounted on the frame rail like a couple of the pictures above...
