Ever since I installed the LCA relocation brackets...
I have adj LCAs and I have set both tires to equal distances from the front of the wheel well which isn't helping much. Is there something obvious I'm overlooking that would've changed with the addition of the brackets (setting to the lowest most hole)??? Car is running good...just can't get my 60' times due to traction problems from inadequately heated tires
went 11.401 @ 123.01 mph last night on a 1.73 60 foot time
You may want to have a 4-wheel alignment done. Since you have adjustable LCA's, you can adjust the thrust angle (whereas you can't with stock parts).
i just need to get the adjustable lca's now so i can put the 28's on.
