Drag Racing Tech
I blew it up!!!!
Old Oct 16, 2003 | 10:35 AM
Noyzee's Avatar
8 second mod
Default I blew it up!!!!
The Moser that is.
Put the new axle in, went back to the track, did my burn out. staged, then dumped the clutch. BOOOOOM,
Got home pulled the cover and most of the rear fell out with the oil. Also cracked the yoke and u-joint in half!!!
Im going with a spool, and 33 splin gun drilled str ange now, Any input on this?
Thanks.
Old Oct 16, 2003 | 10:43 AM
bspz28's Avatar
Default Re: I blew it up!!!!
Spool = race car LOL
Old Oct 16, 2003 | 01:22 PM
SNAXS's Avatar
Hehe at least you know your car has power. How many runs did it last? My car lasted around 80 NItrous out of the hole passes with slicks.
Old Oct 16, 2003 | 01:26 PM
EVIL's Avatar
damn, yuor doing great! mine lasts about 5 or 6 each time. it has never broken, but it is so loud you dont want to drive it!
Old Oct 16, 2003 | 04:29 PM
Noyzee's Avatar
8 second mod
Well it prob has about 200 passes on Drag radials and 26x10.5x16 ET streets, But I got 7 1/2 runs out of the Big tire!
Spool = race car, Yes, But my buddy has one in his car, he drives all the time on the street and it is running 10.0's! He said it isnt even notacable till you have to take a FAST SHARP turn.
We shall see.
Old Oct 16, 2003 | 10:07 PM
TheMightyWS6's Avatar
dude, i was there! i was just telling my buddy who i work with about that today. i don't know if you noticed but i was the black WS6 in the left lane about 3 cars back from you.
i smoked my clutch last night. some guy in an import hit the wall right before my first run so i sat at the burnout box for an hour. finally got up the the tree, dumped my clutch at 3800 and spun it real bad. the stock clutch gave up after a year of abuse and my newly installed drag radials.
here's to a bad night at the NED
i saw you pushing it into the trailer and i would have helped but i was trying to figure out what was going on with mine. when the lights went out i called it a night.
Old Oct 17, 2003 | 06:53 AM
Noyzee's Avatar
8 second mod
I didnt see it, I was not paying much attention after i blew it.
The stock clutch is a junker, I blew mine in no time.
Then I put a good clutch and there goes the stock rear!!! Week links!
Old Oct 17, 2003 | 11:24 AM
LS1LT1's Avatar
I hear good things about Strange 12 bolts, Alex ('WS6TransAm01') has one and it's holding up well, quiet too.
Old Oct 17, 2003 | 11:30 AM
EVIL's Avatar
mine sucks! holds about as good as a bandaid to the bottom of a boat.
Old Oct 17, 2003 | 12:21 PM
Noyzee's Avatar
8 second mod
I was told by a few racers that the rears are good, Both moser and strage, But the internals they use are Not for high power cars, and M6's make it worse.
No more f-n around, Spool time!
Old Oct 17, 2003 | 12:26 PM
Vents's Avatar
9 inch?
Old Oct 17, 2003 | 12:50 PM
EVIL's Avatar
9 inch?
sittin in my garage floor now!
Old Oct 17, 2003 | 02:58 PM
ROB'S SS's Avatar
The Moser that is.
Thanks.
i could be way off base, but a gun drilled 33 spline axle with a spool just sounds like dissaster to me. i run a standard 35 spline in my spooled 9"
Old Oct 17, 2003 | 03:07 PM
Noyzee's Avatar
8 second mod
The Moser that is.
Thanks.
Why is this? Ive seen 31 splin with spools.
Old Oct 17, 2003 | 03:33 PM
Moose's Avatar
I run a spool in my car.. Its just hard on tires..
My 12 bolt is not the best, it was a over priced 10 bolts that i have had nothing but problems with.
I probally have over 3000$ in the rear alone, between intial price, gears, oil, spool and all the other crap..
Old Oct 17, 2003 | 03:51 PM
Noyzee's Avatar
8 second mod
Sounds like what mine is, when It blew, all i could think is, Well, their goes $40 worth of brand new gear oil! .
You run the spool, and it held up nice? Not bad to drive around with?
Which one do you run?
Old Oct 18, 2003 | 01:43 AM
JimmyKash's Avatar
i dont think you can do 33spline gun drilled.....and if you can do that is about equal in strenght to probably 28spline axles
if you want gun drilled axles i would definately not go under 35
Old Oct 18, 2003 | 05:27 AM
RacinLT1's Avatar
i have a spooled moser 9",33 spline axles. had it for 2.5 years and 25k street miles with no problems. fast tight turns are about the only issue,and dont drive on bfg dr's,they will get killed.
i cant complain about the rear,was cheap,and damn near bulletproof.
Old Oct 18, 2003 | 09:41 AM
Noyzee's Avatar
8 second mod
I couold be wrong, But i think they are 33, they might be 35's, But The ones in my buddies car are about 2" thik!! they are 31 spline, gun drilled. He goes 10.0's and 1.4 60'. So they do somthing right.
Old Oct 18, 2003 | 10:26 AM
ROB'S SS's Avatar
The Moser that is.
Thanks.
its not the spline thats the problem, its the gun drilling. ive seen 31's in a spool too, but they sure as hell werent drilled. id cringe everytime i made a tight corner
