Spohn tq arm... 1.4 short times
7 Second Club
From: Grove City Ohio/Port Washington L.I sometimes
Re: Spohn tq arm... 1.4 short times
I went from high 1.5s to mid 1.4s with the Spohn ta.Set it at 3-3.5 degrees negative pinion angle and it will hook real hard.I never broke anything the Spohn ta is a very stout and heavy piece.
Does this mount using both existing OEM crossmember locations (their photo only reflects driver side).
I take it you've had no problem with the floor pan?
Thanks for the info!!!!
No problems with the floor pan. It mounts right to the stock crossmember points. I even ran over a deer with it and it still works. It did tweak the floor pan when that happened, just a little, but nothing else is messed up.
I set mine to -4 and it bites pretty good. Never broke it either. Consistent 1.4x's and some nice 1.3's when I turn it up a notch.
Thanks for the info. I had planned on a -2, but sounds like a little more aggressive works well.
I love this pic so much from Friday, I'll post it again, and note my buddy was in the car with me.
