Drag Racing Tech
Ineffective Weight Transfer
Old Apr 16, 2009 | 02:10 PM
  #41
JL ws-6's Avatar
Race your car!
I don't know what kind of kit you have on the car, but if it's that rich I'd drop 2 fuel jets immediately and see what you get, or take a 1/2 lb of fuel pressure away (if it's a low psi setup, if it's a high pressure setup I'd change the jets)
Get some video from behind the car, that will help tell what the car is doing and will help alot.
Your et for the mph is pretty good, I'm running about 142.5+ mph and only seeing 9.5x so you're doing pretty well so far.
I want to see what the tires are doing on the hit too, if they're really wrinkling and whatnot you may find that if they are wrapping up alot that tubes could help you because they stiffen the sidewall up some.
Video, I need video to help more!
Old Apr 16, 2009 | 02:12 PM
  #42
White2000TA's Avatar
The external video camera broke..... Im looking at a HD version. That should get us some good information.
Old Apr 16, 2009 | 02:15 PM
  #43
JL ws-6's Avatar
Race your car!
I mean someone standing behind the car with a camera. Just get someone to hold a camera and tape the run from behind the car on the starting line, and if possible a run with no changes from the side and get a good look at the tires and see what they're doing.
If you can get it done on a camera that can put it in slow motion, that would be perfect.
Mark a god sized white stripe on the tires too, so when the side view is shot we can see how much the car is spinning at the hit. a 2 inch wide stripe from the rim to the tread would be good.
Old Apr 16, 2009 | 02:17 PM
  #44
I can do that the next time I run. I have video editing equipment so I can slow it down as much as we need.
Old Apr 16, 2009 | 02:51 PM
  #45
ATVracr's Avatar
Lean it out, put some DR's on it and it will 60' , MPH and ET better ..... those tires suck!
Old Apr 16, 2009 | 04:02 PM
  #46
JL ws-6's Avatar
Race your car!
o.k. I just watched the video now that I am home. Car is pulling to the left at launch from what it looks like. Do you have a piece of tape on teh center of the wheel, just to make sure that it's strait when you have it lined up? If not put one on it, it may help.
It's either that, or the tires aren't matched, car is rolling over, isn't square something.
If you can just get the car leaving strait you're gonna see it pick up. you're driving alot, alot more then I have to drive mine unless I get out of the groove.
Something to think about.
Old Apr 17, 2009 | 07:03 AM
  #47
tektrans's Avatar
If the tires are good on the roll out measure and you're pulling to the left, take some pre-load out of the passenger side of the swaybar, start with a full turn and go 1/2 turns from there if it persists. If she's rolling over that's could be why the bar is rubbing the shocks.
Old Apr 17, 2009 | 08:04 AM
  #48
Old Geezer's Avatar
Corner weights are?
Old Apr 17, 2009 | 10:30 AM
  #49
Originally Posted by Old Geezer
Corner weights are?
I havent been able to find a place that can weigh the corners. Anyone know someone that rents the scales?
Old Apr 17, 2009 | 05:31 PM
  #50
02 BLK WS6's Avatar
I'm looking to have my car scaled soon. I'll let you know if and when I come up with something local.
Old Apr 18, 2009 | 07:07 AM
  #51
JL ws-6's Avatar
Race your car!
Ask around the circle track guys if there's a circle track in your area. Those guys live and die by corner weights, they'll all have access to a set.
Old Apr 18, 2009 | 01:50 PM
  #52
02 BLK WS6's Avatar
I think my old high school auto body teacher may have a set. He races in the modified class.
**edit**
He has a set, but is pretty busy since it is dirt track season. I'll see what I can do to help you out Mike.
Old Apr 20, 2009 | 11:49 AM
  #53
Sweet thanks! I have been wanting to do that for quite some time!
Old Apr 21, 2009 | 08:07 PM
  #54
Firehawk441's Avatar
Don't get too tied up in the 60 foot # because eventually you're gonna find that it's not the absolute end all deciding factor as to wether the car is working or not.
You want to be able to leave on all the power without blowing the tires off. If that means a 1.39 instead of a 1.35 trust me you are better off.
The wheelie's are cool and all but at the end of the day it doesn't win races, it's wasted energy lifting the car that should be moving it forward not upward. Best thing you can do is get the car moving forward as hard as possible, not upward.
Oh really?
Old Apr 25, 2009 | 04:23 PM
  #55
Tommyv8's Avatar
Hey Mike, I just realized that the first run in the vid was against me on my 12.68 pass; you shoulda told me you had this.
Old Apr 26, 2009 | 08:48 PM
  #56
Sorry Tommy! I got a video from behind the car on a 9.76@138 1.41 60ft pass. I slowed down the launch to 20%. Does that help?
http://www.fast-ta.org/xvideos/2009/mm4242009.wmv
and for the record... yes i was definitely sleeping at the tree. .327 reaction
Old Apr 27, 2009 | 10:21 AM
  #57
Tommyv8's Avatar
Hey, is that me in your avatar on a different run? I know I've run you at least twice.
Old Apr 27, 2009 | 01:40 PM
  #58
I do believe that is you
Old May 19, 2009 | 03:43 PM
  #59
Ok here is an update. I got someone to get some shots of the cars launch.
http://www.jimd.com/NFME2009/animated_gif.html
also here is a video.
http://www.youtube.com/watch?v=KK_ip6SB3Ik
I believe the animation was a 1.39 60ft. 9.76@139.60
