Drag Racing Tech
60 footing?
Old Apr 5, 2009 | 01:31 PM
ms4z28's Avatar
Default 60 footing?
okay so i have a 2000 z28 stock rear stock suspension with mickey thompson 17" dr's i ran 12.078 @ 119.98 60' 2.0XX i tryed slipping i think i slip a little slow and i also dumped it at 4000 hooked then bogged anything to fix this? or any tips on how to launch better thank you!!
Old Apr 5, 2009 | 01:56 PM
bills98ta's Avatar
What gear ratio does the rear have ?
Old Apr 5, 2009 | 07:02 PM
Ed Wright's Avatar
9-Second Club
4000 is way too low. Should be more like 6500.
Old Apr 5, 2009 | 08:01 PM
ndfrsd6's Avatar
more info please .......stock 10 bolt ? mods ?
Old Apr 6, 2009 | 01:07 AM
ms4z28's Avatar
I have prc 2.5, Ms4, ls6, spec 3, bone stock rear
Old Apr 6, 2009 | 01:14 AM
jetlag's Avatar
If it bogs, then it is hooking too good. You'll need to raise the RPMs a little bit...
Old Apr 6, 2009 | 02:00 AM
ms4z28's Avatar
The only thing is I don't really want to break the rear end but owell 10 bolts are cheap and easy to come by so does any body have an ideal rpm that I should launch at?
Old Apr 6, 2009 | 02:19 AM
jetlag's Avatar
It just depends on your car setup....cam, powerband, gears, tire pressure, density altitude, etc.
You'll just have to try different rpms to launch at. It is called "Test N Tune night" for a reason
Old Apr 6, 2009 | 03:16 AM
ms4z28's Avatar
Yeah thanks
