Results from adding drag shocks?
I haven't ran the car with the current setup but with my old setup I was cutting late 1.6x 60's with M/T's. That was with stock shocks and Strano lowering springs. I have since added ~60rwhp, PT4000 over my old SS3600, cut 150lbs and added LCA brackets. I figure the car to run mid 11's and hit 1.5x-1.6x 60's as it sits.
Anybody with any real world results from adding drag shocks??
Drag bar would work better, but those are a couple band aid's for not having one.
You'd benefit from the shocks. If you want to be able to get the car to leave as good as possible you will need the ability to change the suspension.
I'd try it as it sits simply to have a before and after you add them, and for no other real reason other then that.
http://i2.photobucket.com/albums/y11...n/DSC01147.jpg
