Drag Racing Tech
Couple of questions...
Old Apr 9, 2009 | 02:43 AM
13lu91rS's Avatar
Default Couple of questions...
i have a 96z.. mods in sig.
my pb is a 13.4 @ 104, 2.0-- 60' with stock clutch and new tires(yoko es100's on 18" zo6motorsports)..
since the clutch, here is my best timeslip.. with a zoom 30010 clutch and pretty worn street tires.
R/T - .006
60' - 2.303
330 - 5.932
1/8 - 8.877
MPH - 84.32
1000 - 11.402
1/4 - 13.527
MPH - 106.44
ok my questions are, if i can hook..
will my MPH drop back down?
could i possibly see 12's?
what can i do to improve anything up there^
im sidestepping at around 2300 both times
Old Apr 9, 2009 | 05:32 AM
98CamZ28's Avatar
I think the MPH should stay very similar to where it is on your most current pass and even with a crappy 2.00 60ft, i'd think you should probably see 12's, albeit high 12's
Old Apr 9, 2009 | 06:13 AM
JL ws-6's Avatar
Race your car!
If you can get the car to 60 foot a 1.9 you will see a 12 second pass. The mph isn't going to change much without a change in the weight of the car or a power level change.
MPH is directly related to the weight and power of the car. you can get a car to ET better or worse without changing either the weight or power, but the mph is not going to have any dramatic change, maybe +/- a mph or so, but alot of that can be weather conditions as well.
Old Apr 9, 2009 | 06:18 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Given that you have basically no mods, that is a decent MPH.
To do better, buy a rear rear end, or swap a auto in there and at least a M/T ET Street radial, if not a bias ply. Then a gear change and let that thing fly.
Old Apr 9, 2009 | 11:06 AM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
Yes, with a 2.0 or better 60 foot you will click off 12s. There are a few threads on 6-speed tips, and you'll find them.
Good luck!
Derek
