Drag Racing Tech
Race Alt. mount?
Old Apr 17, 2009 | 02:52 PM
djsanchez2's Avatar
Default Race Alt. mount?
Hey fellas,
Has anyone used this (or a similar) race alt. mount? It looks to simple to me, like all the tension/weight is being held by one bolt.
http://cgi.ebay.com/ebaymotors/LS1-R...Q5fAccessories
Old Apr 17, 2009 | 03:28 PM
millerpa's Avatar
i have this one http://www.speedinc.com/cont.cfm?cid=C0000531 but havnt got the car running to test it out. but they work fine.
Old Apr 17, 2009 | 06:14 PM
383lt1impala's Avatar
I rather get the bmr one it. 2 bolts is better than 1.
Old Apr 17, 2009 | 06:42 PM
firefighting1101's Avatar
i got the BMR one but it doesnt fit iron blocks...so i have to alter it to make it work...havent gatton that far yet though
Old Apr 18, 2009 | 12:37 AM
LS1SpeedAddict's Avatar
I was able to alter it to fit my iron block, I'll try and take pics later today to show you how I did it.
Old Apr 18, 2009 | 07:13 AM
JL ws-6's Avatar
Race your car!
I have a bmr one on my ls2, but if that setup there was available I'd have probably taken that route instead. Looks like a nice setup IMO
Old Apr 19, 2009 | 12:31 PM
TJ's Avatar
TJ
i use a std chevy alternator bolted directly to the front hole in the block, and a heim joint to tension the belt.
it runs off the a/c side of the crank pulley. its near perfect alignment.
7500rpm, no belt slingage.
ive run it with and without a backbrace, same results, but i have a lil homeade backbrace on it just for peace of mind.
Old Apr 19, 2009 | 09:24 PM
Here's mine, BMR kit that I modified because I have a 6.0 block
Old Apr 19, 2009 | 11:36 PM
djsanchez2's Avatar
TJ think your design would work with a belt to the water pump as well? More pics please I have an iron block as well.
Old Apr 20, 2009 | 07:11 AM
tim99ws6's Avatar
Here's the one I use. It's by a non-sponsor, so just pm me for details. But it also uses a smaller denso alternator(considerable weight savings).
Old Apr 20, 2009 | 07:31 AM
Fireball's Avatar
I still use the stock alt bracket and relocated the tensioner (something Tom the Roofer did many years ago which I copied )
mount the tensioner on the back side where the idler pulley used to be (have to clearance the webbing on the alt bracket). its held in by one bolt, but it sits tight against the bracket on the bottom so it can't rotate. Works so far up to 8000 rpm
Best part is that its FREE
Old Apr 20, 2009 | 12:12 PM
TJ's Avatar
TJ
you would need an alumium spacer to bring the alternator out to run on the 6rib so it would line up on the water pump pulley.
the pulley is pretty wide, but i dont know if it would stay on it or slip off the back.
itd doable for sure.
my alt is mounted directly to the block.
this is an older pic on my stock 6.0, but same setup.
