Drag Racing Tech
et drag question
Old Apr 19, 2009 | 01:10 PM
subhumanzz's Avatar
Default et drag question
i am getting tired of spinning these hoosier DR's. i am looking to go to an et drag or equivalent. the car has a 9" w/4.11's, spohn rear sway bar, spohn lca, rlc brackets. spohn tunnel mount tq arm, no name panhard, comp. eng. rear shocks (set @ 50/50). the car is at stock ride height but i dont know if i will be able to run a 28" slick without having issue with it growing to big. so i am thinking of going with a 26x11.5x15. i am just not sure of which style i need i.e. stiff wall. the car is an m6. i am not sure if the power level matters but the car made 495/518. so if anyone with experience with et drags and a m6 could point me in the right direction i would greatly appreciate it.
Old Apr 19, 2009 | 02:05 PM
ndfrsd6's Avatar
they will grow about 1 inch now if you have tubes in them i dont know if they'll grow as much....do you have front shocks ? that will help big time ! transfer the weight to the rear!
Old Apr 19, 2009 | 05:10 PM
subhumanzz's Avatar
front shocks are next on my list. i am just trying to figure out what et drag m6 people are running.
Old Apr 19, 2009 | 05:36 PM
ndfrsd6's Avatar
et drag stiff wall for a m6
Old Apr 19, 2009 | 06:53 PM
subhumanzz's Avatar
these are what i am thinking of getting:
Mickey Thompson #672-3053S
# Mickey Thompson ET Drag Slick26.0'' x 10.0'' - 15''
More Details $183.99
3053S - Mickey Thompson ET Drag Slicks Details
10.0'' Tread Width
Tire Overall Diameter: 26.5''
Average Roll Out/
Circumference: 83''
Tire Tread Width: 9.8''
Tire Section Width: 11.5''
Wheel Diameter: 15''
Spec Wheel Width: 10''
Tire Weight: 24.0 lbs
Suggested Tube
Part Number: 672-9553
Old Apr 19, 2009 | 08:18 PM
ndfrsd6's Avatar
yes those would work with your setup
Old Apr 19, 2009 | 09:23 PM
subhumanzz's Avatar
how will they affect my gearing going from a 28 to a 26?
Old Apr 21, 2009 | 06:30 PM
subhumanzz's Avatar
could use a second opinion here. i just wanna make sure i get what i need. can i run a 28 in a full slick without any issues? what will going from a 28 to a 26 do to my gearing?
Old Apr 21, 2009 | 08:40 PM
N2RACINGLS1's's Avatar
So I am confuse are you currently running a DR that equals a 28 inch tire. If not I would run the 26X10X15 S ET Drag. You need the S (Stiff sidewall) for a heavy spd car. If you run a 28 inch you will need to do some trim work check search for info. You will need to make sure the tire is centered in the wheel well.
I run the tire you are asking about in the stiff model and I go through the traps with a TH400 at 6,600 RPMS NA and 6,900 RPMS on a 75 shot of nitrous with the same gear.
I hope this helps good luck!
N2
Old Apr 22, 2009 | 01:17 AM
SuperSlow02's Avatar
I ran a 28in ET street with no issues...The only experience I have between the two sizes is a 26in worked great for motor pass....weak *** 350hpish....and on a 150 shot a 28in tall tire worked at great, the 26in just wasnt enough with 4.11s...Cant remember the trap RPMs though..sorry
Old Apr 22, 2009 | 01:35 AM
gold98Z28's Avatar
yeah, i think the 26in tire works better na, if you get the front to pop for ya. and the 28 works better for a decent size shot. you can hook it on the smaller tire if your suspension is right tho. a 27 in QTP hoosier is another good option
Old Apr 22, 2009 | 01:14 PM
subhumanzz's Avatar
yes i am currently running a hoosier dr. 325/50/15 (28") but the problem with this is that i run at a sketchy track that doesnt always provide the best traction. therefore i am looking to go to a full slick. the difference is that i was told that at 120mph a slick will grow almost 1". therefore i was thinking if i ran a 28 i would have problems on the big end of the track as far as growth on the tire.
Old Apr 22, 2009 | 03:50 PM
ndfrsd6's Avatar
you'll need to trim a little on your rear fender but the 28 slick will be fine ....
