Spool for stock 10 bolt?? Help out the v6 guy please!!!
OK, in 3 years I have blown up 3 LSD units ![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
N/A with 3:23's I have pulled 1.88 60 foots.
Spraying a 100 shot I spin to low 1.7 60's all day long
I tried ET drags and on a very poor launch I blew the tranny and a fuel solenoid and went 1.63 with 3:23's on a 100 shot.
My power is ALL low end, nothing top end.
Old dyno was 380 rwtq plus a 3200 pro yank converter.
Since the day of the 1.6 60 ft I had the tranny built for a 10-11 second car.
I launch at 3,000 and spray at 3200.
I am trying to up the shot to a 125 shot.
Keep in mind, this is a TNT wet kit. We ALL know how TNT kits are... right?
On my 100 wet TNT I saw a gain of 136 rwhp so you do the math![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I'm fed up with LSD.
I no longer drive the car everyday.
Does anyone know of a spool for a stock 10 bolt GM rear?
I called SUMMIT and they did not know of one. I will not upgrade to a 12 bolt because all my local 10 and 11 sec ls1 buddies lost 7-10 rwhp. On their cars power loss isn't a factor, on my V6 power loss is a BIG factor.
Also the benifit of the spool would free up a bit more lost HP.
I'm a big effeciency nut
170 RWHP and it goes 14.2 is not half bad... right?
Soooo, long post.....
I'm looking for a spool for a stock 10 bolt, can ya help out the little v6 guy???
Thanks in advance!!!
LS1TECH Sponsor
James.. you're not blowing things up due to power.. I'd look at the installers. If this is a regular thing somethings up.
What you can do is get an open differential and have it welded at all the gear points to make it a spool.
there is no direct bolt in spool.
