Where is my MPH going.....?
I see all these stock internal A4 cars running 11's @ 115. Hell, I had a buddy here in OKC run 12.3@113 on a 02' WS6 M6 with lid, headers, and tuning. How much could be do to the DA? The regular altitude of the track is around 1200 ft, and I think I calculated a DA of 1600 or so last time out. Surely it isnt killing it that bad.
Any ideas....?
EDIT: a TNT 75 shot pushed it to a 11.7 @ 117
I am also noticing about a 100 Mv difference in the O2 sensors....?
Loco, what do you MPH at?
What size slicks you runnin. I always MPH better on drag radials than slicks. That big of a stall is gonna lose some MPH. Looks like you added alot of things at one time. Give yourself some time to figure out your combo. It shall come. Took me 2 years to figure out my combo.
Good luck.
BTW: Thunder valley isnt the best track.
Stu
1) What size slick are you running?
-if you are running a 28" slick, its going to hurt your MPH compared to a 26" tire. My car saw 2MPH more last year when I tried some 26" tires for a couple passes.
2) Locking the converter? And at what point in your pass?
3) Getting any KR??
4) The LS1 Edit tuning of course could be part of the issue, as well as the shift points.
I am never locking the converter, I have thought about it, but havent found a good diagram on how to wire it it in.
No KR on the runs I was describing
I know I need to play with Edit a whole lot more.
So does the amount of timing seem sufficient? What about the big difference in the O2's?
I went to the track on my 18" ZO6 wheels with Kuhmo tires, and ran a 12.8@111 with a 2.0 60'. The later switched to the slicks, it definitely helped the ET, but I thought I would see some more MPH outta that too. Guess not
I think the main problem is that you need to "Tune"... Good luck and let us know how you make out..
-George
Not locking up the converter on a stock bottom end/compression car is going to cost several MPH from my experience with these cars.
You lock up the 'verter and I bet you'll trap a few MPH more right away just from that. We've gained even more in the past by just making passes and messing around with it and locking it up at different points going down the track..locking it like the top of 3rd gear seems to be a good starting point for most cars with a good sized stall.
Does the cam have any advance?
I have friends going 113-115 mph with light cars and stock internals.
Do me a favor and post a whole slip.
The MPH was was I was worried about for the reason Silverghost posted, that I wanted to know what kind of HP the car was making, since putting an A4 with a 4000 stall on the dyno wouldnt tell much.... According to some of the calculators I have come across, and inputting the 12.2@111.5, they state I am putting down around 380-385 HP at the wheels....
my car is having the same kind of probs
here is my slip
60....1.713
1/8...7.812
mph..87.5 .....what a turd!!!
1/4...12.2949
mph..109.65......again turd
I have a 98 formula
probably weighs 34-3500 w/me
slp longtubes,y/pipe slp dual on the left cat back
yank tp 4000 stall
asp pulley
373 gears
I am shifting the car at 6300 also in first 6250 in 2nd
I will be upgrading to 3.73's this winter, and hopefully doing some dyno tuning somewhere in there.
Heads are getting put on soon too, as I am just waiting for the intake valves to show up
What shift points would you reccommend with that size cam Colonel? I have the rev limit at 6600. I just dont have the money to fix something that breaks right now, by running the car to too high of a RPM. I know, breaking stuff is racin, but I would rather just be smart and safe about it for now. What do you think a stock bottom end 98' with 90,000 can withstand...?
If I advance the cam, won't that bring the powerband down in the RPM range some, to save me from some of the high RPM's...?
