Drag Racing Tech
need to pass tech for LSX shootout
Old May 6, 2009 | 11:38 AM
silverbeast's Avatar
Default need to pass tech for LSX shootout
Hey guys, im trying to get my car ready for the shootout in memphis and i need to know what all i will have to have. My car has a roll bar in it now but i will be adding door bars before i go. It has a Th350 w/ a blanket but if you look under the car you can see the flexplate so what kind of sheild will i need and which one fits the best. The car should run high 9's or around 10. 0's on gas. I have a drive shaft saftey loop and the rear has the 5/8 studs so i think im good there. I also have the 5 point harness but i havent checked the dates on them. what else will i need? Thanks
Old May 6, 2009 | 12:01 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Id grab a NHRA rule book and put in what is required for the fastest time you expect.
Old May 6, 2009 | 01:19 PM
thanks dude. i just looked at the CSR sheild in summit and it looks nice, is that all i will need for the tranny?
Old May 6, 2009 | 01:36 PM
Internet Mechanic
Most times yes, as long as you can get the SFI rating and the # associated. From what I have learned, get all those numbers or cars and have it written clearly on a sheet of paper, even Laminated and keep it with you. The Tech guys appreciate people being prepared and to pick over the car less.
Does the CSR sheild cover for the bell housing?? That is also a cause for concern, again depending on ET and MPH. I went on summit and had a whole mess of different styles
Old May 7, 2009 | 01:42 AM
thanks for your time. Im pretty sure the car will run around the 10.0 mark so thats what im shooting for.
Old May 7, 2009 | 04:17 AM
JL ws-6's Avatar
Race your car!
CSR shield covers the whole tranny and takes care of that, that's what I have on my car.
driveshaft loop, battery shutoff if it's relocated, up to date harness, metal valve stems in the rims, long enough front and rear studs (rear's are good if you're on a 5/8 for sure) SFI approved flexplate and balancer.
That's all I can think of, I don't have the rule book in front of me but I'm sure that's 90% of it if not all of it.
Old May 7, 2009 | 06:59 AM
REDGAR's Avatar
Make sure your helmet is up to date too..2000 and if you are going 9s it has to be full face
http://www.nhra.com/competition/etquickref.aspx
Old May 7, 2009 | 11:56 PM
thanks guys, that helps alot.
Old May 11, 2009 | 11:48 AM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
Check the NHRA tech thread I created for this very question, it will be in the sticky section. Come prepared, NMCA tech will check everything.
Derek
Old May 12, 2009 | 10:29 AM
I found that sticky yesterday Derek... its very helpful. thanks.
Old May 21, 2009 | 06:37 PM
MIGHTYMOUSE's Avatar
last two years i've been caught for
out of date helmet
out of date belts
no pants
no shoes
no neckbrace
no gloves
so i can tell you for shure the check for that crap
Old May 22, 2009 | 09:16 AM
tim99ws6's Avatar
out of date helmet
out of date belts
no pants
no shoes
no neckbrace
no gloves
Couldn't agree more. They dinged me for some pretty tick-tack stuff as well last year when we were there.
Old May 22, 2009 | 11:51 AM
buzz12586's Avatar
Out of date belts is the biggest BS they have going. Unless the belt has been cut or in a serious wreck it doesn't just go bad after 2 years. This is just the NHRA trying to make more money.
