6spd guys please come in!
I am running a m6 4:56's with 432 rwh in a '72 ss camaro all cal trac with split monos .i am looking for set up details ,i am leaving on the limiter at 7k .if i set tire pres to hooook it will nose over a lil & recover.i have played with tire pres alot!i am running 3 way adj on fnt set 90/10 with 9 way adj on back.thanks for any & all input.no i do not want to switch to an auto!!!!
I am running a 90/10 ste up on fnt.the backs were all the way up firm .do i need to soften the rear a litlle like a 7 out of 9 on adj. Or leave firm .also on tire pres ,just set to hook & then play with my shock settings.what tire pres are you running.i use a 28/11.5/15 et street.
Internet Mechanic
But from what I understand is the fronts have only 3 settings, you may need to get at least 10 way all around and as long as the front is a 90/10 shock then your 90% of the way there.
PM the Dragracing Moderator JLws6, he knows settings extremely well and I am sure can give you something to work with.
