What do you think?
race 1 race 2 race 3
r/t -.492 .575 .818
60' - 2.248 2.336 2.348
330 -6.293 6.358 6.396
1/8 -9.541 9.571 9.642
mph -76.39 76.81 76.38
1000 -12.275 12.289 12.362
1/4 -14.609 14.608 14.619
94.95 mph 96.82 100.69
thanks for everyones input im very anxious to see whats wrong
Did you burn out in second?
How long did you burn out?
Im guessing you had your sway on and did not get the tires hot enough by that 60ft.
-tb getting wide open throttle
- which tune
- datalogs to see if the car is pulling timing and how much
- are you hand shifting the car or just putting it in drive, either way what are the shift points and I would be leaving it in drive?
got to start somewhere, don't give up, you'll get
As for your last visit, did the car bog off the line? did your tires spin? how many miles on engine and spark plugs? What gears ya got? 14.6 ran you, V6 sure you not have?
*forgot to ask if you had the TCS on if your car is so equipped.
I forget how it translates but something like every .10 off of your 60ft is .30 off of your quarter mile time.
Get a professional to look at it and figure out what is going on. It would be money well spent.
How were you launching the car?
With my old 00 LS1 A4 I would run 12.7s@108 wit the same basic mods as you and sway bar still in the car, full weight with nittos. Main difference was I ran stock manifolds, stock y and cats with a random tech cat back. I would shift the car myself (remember youll have to shift about 500rpms early to time it right) and I would leave stalling the car to about 1500 on the stock stall.
