Drag Racing Tech
What tire pressure for skinnies
Old 07-03-2009, 08:36 PM
Mark98SS's Avatar
44 on MT Sportsmans
Old 07-03-2009, 09:10 PM
tektrans's Avatar
Originally Posted by JL ws-6
They look flat because they aren't designed to carry that much weight. All of teh VW tires are a VERY unsafe thing to put on the front of a car that's going to see 120+ and is as heavy as these cars are.
I would STRONGLY reccommend a set of the 8 ply, or at least the 4 ply sportsman front tires. I ran the 4 ply and they were fine @ 40 lbs... the VW tires that I have seen people use, don't look right even with 50 lbs because the sidewall just can't support the weight. Now, imagine having to make an evasive maneuver with that tire on the car, they'll roll right over and then you're gonna be in trouble. At the track, car gets sideways on you say 150 feet out because of some oil the last import left on the track, then you'll find yourself in trouble too. Nevermind if you stand the car up, and it comes down a little hard, even from a 2 foot wheelie.
Ditch those tires please as soon as possible.
100% right, couldn't agree more.
I run the mt sportmans 8 ply at 45psi or so mainly because that's what psi I drive around the street on and I'm usually too lazy to take it up to the tires max pressure of 60 psi.
Old 07-03-2009, 10:50 PM
billybadd's Avatar
45 on MT 8 ply's here.
Old 07-03-2009, 11:28 PM
bigsticksupra's Avatar
what do people with M/T ET FRONTS bias ply run? i usually put my to 45 as well... should i put more air in?
Old 07-04-2009, 07:36 AM
Race your car!
JL ws-6's Avatar
I run a moroso ds2 now that the car is a track only car and is light enough for them.
I run them at 40 psi as well.
Old 07-04-2009, 10:12 AM
FASTFATBOY's Avatar
I run 50 in my M/T sportsman fronts.
Amazes me that people spend thousands on a car and want to skimp on something that could very well kill you, or at a minimum trash your car...all over a couple hundred bucks.
Old 07-07-2009, 07:32 PM
kmracer's Avatar
but seriously, when has there been an accident BECAUSE of khumo front runners? i always see you guys saying oh no stay away, but when you can get 2 tires for 80 bucks, how can you go wrong?
Old 07-07-2009, 09:25 PM
scrapmetal's Avatar
Originally Posted by mrdragster1970
On the street, a lot of guys run a little over what's marked.
On the track, guys have gone 10-15 over their number.
Old 07-07-2009, 11:05 PM
CamaroRacing12's Avatar
i got the kumhos, i run them at 44psi as stated on sidewall as max tire pressure, i might try upping them a lil more tho seeing as some people run them higher then max.
Old 07-08-2009, 02:27 AM
TA1364's Avatar
I ran them close to 50 this weekend and it seemed ok.
Old 07-08-2009, 04:46 PM
Z-RATED94's Avatar
Your kidding, right? Their cheap and how could you go wrong? What happens if one does let go? Your willing to take the chance with your car and the one in the other lane? Not me.
I had those in my possession before finding out the speed rating. Took them back to the tire store, explained the situation, and they agreed about my safety concerns and had no problem taking them back and ordering me the right ones.
Old 07-10-2009, 08:40 PM
  #32
kmracer's Avatar
ok... BUT, as we all know, there is very little weight (load) on the front end when accelerating, and the tires might be above 120 for how much time? hell, if the car is an 1/8th mile car, it might NEVER see that speed.
why waste money? sure, if the cars a sub 10 second car, defintly run the right tire, i can agree. but for something thats gonna see 120+ for short bursts, 4 to 5 seconds, why waste 300 bucks?
Old 07-10-2009, 08:47 PM
  #33
FASTFATBOY's Avatar
You kinda got it backwards there dude. Its all about how the tire reacts in a PANIC situation. The overloaded VW tire is likely to roll off the rim in a panic type deal. Or think about this, you hit a slick spot on the track at 85 mph and try to correct the car.
You skimp on brakes also dont ya? Cheapest pads and rotors you can find?
Old 07-10-2009, 08:58 PM
  #34
ATLSS's Avatar
This thread is FULL of FAIL.
I can not believe some of you idiots would run a low rated tire at the drag strip....
What a damn shame...
The worst part is, you just might cross the lane into ME... ******* idiots... spending THOUSANDS on their motors... and only $39 on their front tires that could wind up KILLING them or ME....
I bought M&H bias ply front runners... and I paid $150 EACH... and was HAPPY to do it for MY safety and YOURS...
Old 07-10-2009, 09:03 PM
  #35
ATLSS's Avatar
Go die in a fire with your Kumho tires...
You can't even spell the name right man...
Old 07-11-2009, 12:53 AM
  #36
TA1364's Avatar
Alright will do, thanks.
Quick Reply: What tire pressure for skinnies
