Drag Racing Tech
Need drag radials
Old Jul 17, 2009 | 06:53 PM
jetfastformula's Avatar
Default Need drag radials
Hey guys I took my formula to the track for the first time last weekend and was a little dissapointed with my times I got a best time of 13.9 @ 109 mph and spun through 1st and 2nd really bad launching at 3000rpm. I was wondering how much better my time would be with some drag radials. Not real familiar with race tires so what would be good? Also is it better to turn the tcs on or off when racing? Mods are in singnature. Thanks
Old Jul 17, 2009 | 11:04 PM
dlk1950's Avatar
Mickey Thompson DRs will help a lot,,easy launches at first the MTs will bite so be careful you don't break your rear....Turn TCS off.
Old Jul 17, 2009 | 11:12 PM
LCplmarine98's Avatar
I have Nitto NT55r DRs and they are awesome. When i go to the track i got down to about 15psi and dont break loose. On the street at normal PSI i can mash the throttle and barely spin. I love em and they are priced alot better then MT
Old Jul 18, 2009 | 01:21 AM
I didn't think about it at the time but i run 32psi in my tires normaly and that is what i raced with would it help if i lower the pressure before i race? If so what psi should i run? also i have goodyear eagle F1 tires so do i need to do a burnout or is it better not to when running street tires?
Old Jul 18, 2009 | 01:48 AM
jetlag's Avatar
I'd have BFG DRs and M/T DRs. I like the Mickeys best.
Old Jul 18, 2009 | 02:40 AM
caviness's Avatar
street tires drive around water box and just burn them a little to clean off the tires not a smokey burn just turn em over a little,and you will have to lanch at a lower rpm to hook like 2000 or 2500 if track prep is good if not its just going to spin,MT DR will hook the best but your rear wont last long maybe 1 pass maybe 25 passes but it will just be luck
Old Jul 18, 2009 | 08:55 AM
CaMaRo67RS355's Avatar
M&H or Mickeys FTW
Old Jul 18, 2009 | 09:19 AM
Juicy J's Avatar
You have a lot more in it with out buying drag radials. You could run high 12's with out drag radials with that mph with an average driver.
Old Jul 18, 2009 | 08:56 PM
taws6m6's Avatar
100 bolt?
Old Jul 19, 2009 | 08:54 AM
mike c.'s Avatar
The m/t drag radial is best for the track. Nitto is a great street tire(they last long) but at the track no way. if you can get a second pair of rims like LT1 rims from the junk yard 16'' and slap the DR's on them. Run them about 15 to 18psi. I saw 5 tenths drop off my times back in the day when I was only a 13sec car. Tcs off and start your luanch around 2,200rpm's and go up ti'll you find the sweet spot. goodluck to ya.
