Cam Only Times
Ran 12.48 @ 115.74mph with a 2.059 60ft time. 'da was around -1000ft. Not sure what the elevation at GLD in Union Grove where I raced. This was on regular radials (sumitonos) and through the catback. The engine is running with the stock tuning. Completely stock the car ran a best of 13.29 @ 107mph with 2.12 60ft time.
Im really happy with the times considering the engine hasnt been tuned. The biggest improvement will come from raising the rev limiter. According to the MMS website this cam in a vette with stock heads makes peak power around 6400rpms. Shifting before the rev limiter at 6200rpms is way too low.
Traction wasnt too bad with the sumitonos. Removing the front swaybar actually seemed to help. Its noticable but not to the extent of drag radials. Launching the car was fairly easy. I was launchin around 2500-3000 at part throttle then flooring it as the tires hooked up. That seemed to work the best.
My goal is to get the car into 11's on regular radials. I think it might be doable. Some mods left to do are: ported tb, underdrive pulley, short belt, fra, real ram air, 200lbs of weight reduction, moving the battery to the back, cutout, and tuning.
Im staying away from drag radials. Had a pair of nittos for awhile and the stock clutch couldnt take it. The pedal would get all spongy and stick to the floor by the end of the run. Then there was a problem with wheelhop. The nittos hooked pretty good but they were brutal on the driveline.
Anyway it was a lot of fun at the track. There was less than 10 cars racing so there was no waiting between runs. Made a total of 17 passes, 5 of them back to back. The car didnt skip a beat. Even the clutch was working good.
Thanks for the encouragment and good luck with your 2004 racing season.
99-LS1-SS
Getting a cam can be as cheap as headers if you do the install yourself. All you need is a used cam and some springs.
red fury
I love that tr cam. That has to be the standard street strip cam for ls1's. You need some weight reduction. Youre so close to 11's, all you need to do is take 100lbs out of the car and youre there.
StreetStalkerZ
Im still kickin myself for not getting an A4. There are A4's runnin quicker with just a converter W/O headers or cam.
taqwache
Yeah, I got the crappy mac headers. Still I dont think they are slowin the car down. I know 4.10's will help but dont feel like investing money into a failing 10 bolt.
Vents
Im not expecting too much from a tune. I figure the computer will run the engine rich without tuning. But because this year only has 26 lb injectors it can only run so rich. Maxed out the injectors can only provide enough fuel for 420rwhp. This cam has been known to make over 400hp. So how rich can the engine be? Im guesing most of the power from tuning will come from timing and raising the rev limiter.
LOL these numbers seem kinda weak compared to some stock internal cars. What made me happy was the improvement from going from 13.29 107 to 12.48 @ 116. THe car picked up almost a complete second and 10mph from $1200 in mods. Too easy.
Car ran 11.46 @ 121.xx MPH... The car is a pig and needs some suspension work but the MPH was pretty insane for bone stock ls6 heads.
- Matt
but i dont feel like pulling the cage and all that weight again. Josh S.
Streetstalker has a slow POS so dont worry bout him LMAO HHAHAHAHA j/king bro
bascially all you need to do is find traction and you will have a easy 11sec car. But like mentioned above you may wanna invest in a 12 bolt or 9inch for your M6. A4's are easier on the 10bolts but M6's like to go through them!
good luck... your times will get better and better everytime out as you figure the car out more also
I should be going to the track saturday IF i get the PCM back in the car tomorrow night after the new tune.
