Where to start with suspension
$700 plus shipping
Bobby 281-413-0592
Used one year. Boxed up and ready to go.
Go adjustable its nice because if you get a new rearend you will want to center with and adj panhard bar, you get 28in tall tire you will want to center those in the wheel with adj lca arms. Get a adjustable trq arm so you can adjust the pinion angle as needed. Every car is different and will react different to parts. Need to play with the suspension and find out what works best for you. Don't waste you money twice get adjustable everything the first time!
Here is my phase I approach:
!front swaybar
aftermarket LCA's
Front QA1 R shocks
The shocks can keep the front end soft during the launch. The R shocks if they still call them that will keep the nose from dropping and bouncing like the very first shocks sold by QA1. Aftermarket LCA's will help because your stock bushings are probably all beat up and causing your wheelhop. For a mostly street car stay with poly bushings in your LCA's, don't do rod ends, because they can be a bit clanky.
Phase II:
Rear QA1 shocks
PHB
Phase III:
Torque Arm
Madman travel limiters
Phase IV:
Make more power
Larry
Found it:
https://ls1tech.com/forums/suspensio...-60-bucks.html
and another post
https://ls1tech.com/forums/suspensio...-i-cant-3.html
OP, you have to fix that wheel hop so you don't break your rear end.
it doesnt make sense to me if im dead hooking that more suspension would make my sixty faster...
i have BMR suspension.. LCAs Springs TQ arm panhard bar etc etc.. drag bar is one of the few suspension components i dont have.
i guess my question is....
if your hooking with LCAs only.. then you add tq arm pan hard bar and drag bar... are you going to go any faster?
