Drag Racing Tech
Where to start with suspension
Old Aug 2, 2009 | 03:47 PM
TA1364's Avatar
Default Where to start with suspension
Mods: Pt4400, headers, ls6 intake, p&p throttle body, no front sway bar 15" wheels with 26x10.5 mt ET streets at 14-15lbs. Best I can 60' is 1.69 letting it hit 2nd gear and driving away as far as I can during the burnout.
It doesnt blow the tires off but it chatters/vibrates/wheel hops however you want to describe it. Theres no point to add any more power untill I can dead hook what I have. I am on completely stock suspension, where do I start? I am thinking I need more weight transfer. Theres no reason these tires shouldnt hook up.
Old Aug 2, 2009 | 04:34 PM
cbra-klla's Avatar
Lca. Torque arm, rear sway bar
Old Aug 2, 2009 | 06:16 PM
TA1364's Avatar
Would front shocks benfit more than a torque arm?
Old Aug 2, 2009 | 06:55 PM
Black 99 Bird's Avatar
Drag bags?
Old Aug 2, 2009 | 10:11 PM
lemons12's Avatar
drag bags are cheap and can help a lot depending on the car.. all you need is one on the rear right..
LCAs, TQ arm would be my starting point.. if that hooks you thn run that until your making enough power and start spinning again.. then look into more things.. rear sway bar etc...
Old Aug 3, 2009 | 10:24 AM
TA1364's Avatar
Would I need relocation bracket? Im on stock ride height tho.
Old Aug 3, 2009 | 03:56 PM
omcar's Avatar
LCAs, adj torque arm, adj QA1s rear/front
Old Aug 3, 2009 | 07:21 PM
TA1364's Avatar
Preference on the adj torque arm?
Old Aug 3, 2009 | 08:58 PM
lemons12's Avatar
no, you dont have to have them.. they are nice though.
not ******* you.. but why everything adjustable..
my opinion.. dont get anything adjustable.. not only do you not have to worry about fooling with it.. its cheaper!
Old Aug 3, 2009 | 09:13 PM
tittan1500's Avatar
go adjustable it is not hard to set it up at all... setting pinion angle can make a good difference and when get adj lca so you can center your axle and add relocation brackets
Old Aug 3, 2009 | 09:26 PM
TA1364's Avatar
Im not going to be adjusting things all the time. I'd rather set it up once and be done with it.
Old Aug 3, 2009 | 09:57 PM
GIZMO's Avatar
A passenger side air bag and adjustable front shocks would be a good starting point.
Old Aug 3, 2009 | 10:20 PM
TA1364's Avatar
Would that help out more than a torque arm?
Old Aug 3, 2009 | 10:42 PM
StreetSilverado's Avatar
Go adjustable. All you have to do is adjust it right the first time and your done with it. Shocks/Springs, LCA's, Panhard, Torque Arm, etc. BE SURE TO HAVE EVERYTHING SQUARED OFF! That's a big mistake lots of people make when bolting on suspension, they just slap the **** on there and call it a day. WRONG.... My grandpa and I are also going to try a whole different set-up as far as the rear sway bar is made. More of like an Anti Roll thing that we put on the "Super Outlaw" cars run. I'll post pictures of it when it's built and done.
Old Aug 3, 2009 | 11:09 PM
lemons12's Avatar
no reason to bed your hang little buddy...
just a simple question to him... not you.
some people have a budget set in mind... that is one MAJOR reason not to go adjustable..
Old Aug 3, 2009 | 11:11 PM
True, but if you wanna do it right go adj.
Torque Arm would be my first concern IMO.
Old Aug 3, 2009 | 11:19 PM
lemons12's Avatar
true... i have non adj. and i dead hook.. low 1.53 short times on motor with a 26" ET street... full weight..
and yes, TQ arm and LCAs would be first two..
Old Aug 3, 2009 | 11:25 PM
It's all clear to me now...just put double sided tape around your tires and BAM, THE ULTIMATE TRACTION!
Old Aug 3, 2009 | 11:32 PM
lemons12's Avatar
my god.. you have not been doing this?????
where you been?
Old Aug 3, 2009 | 11:33 PM
I just wasn't using the double sided tape
