Drag Racing Tech
Manual brakes on DD
Old Aug 19, 2009 | 11:45 PM
brandonppr's Avatar
Originally Posted by tals7
i am having same problem with no breaks on top end.how did u disable abs before you removed it?.
ABS fuse.
You will have a light or two come on. I pulled the gauge cover off and but black tape behind the words.
This might be an alternative.
Originally Posted by Sideways240sx
Yes abs light and brake light. On a 98....
pin 7 to pin 12 turns the ABS INOP light off.
pin 16 to pin 12 turns the BRAKE light off.
Pin 12 is a ground so you are grounding these wires out, and it turns off the light. Much better then pulling apart dash and brekaing/taping bulb.
That info came from steve @ sjm and i run his abs delete kit on my car. Works and looks great. For other year fbodies i dont know if wirring is the same.
Chris
