Manual brakes on DD
i posted in here because i should posted here instead of brakes area all those guys want is power everything lol
On a weekend cruiser it is nice but not a DD.... Taking weight off the front only really helps when you go to manual steering...... I loved manual steering but my last car was not anything close to a DD. Leave the ABS in untill it breaks and leave the paower brakes in...
Do a search.... lots of threads on this.
Manual rack with skinnies only really sucks in slow tight turns.
Not sure why ABS would be pointless with skinies and "fattys"... I could see it being a little more sensitive on the front wheels but that is about it.... there are Honda's out there FACTORY with wheels not much wider then the skiniest street skinies....
Something tells me your tires out back are not slicks or radials..., most liley street tires.... on a DD I would not be on stickies and skinies.
I had manual brakes and steering in my 83Z and did not mind it but it rarley got out... I took the same routes to cruise in's and was not worried about having to get around some idiot about to hit me... on a DD you can't have that luxury and tried to make a fast hard turn in a car with skinies will most likley end badly not to mention if you have manual steering in a car with most of the eight up front.
The steering radius is worse if you don't get the right rack....
Maybe your buddy had something wrong with his brakes before he went manual......
Do a search on here and see how many people say no NOT have manual breaks on a DD........ Call Burkart Chassis or Madman and see what they say...
With a DD you are limited at what you can do unless you don't care about saftey........ a molly k-member alone will save more weight then a manual rack and brakes..... want to save more weight???? ditch the factory carpet, or get a molly fab 9 inch....
Not sure how a manual rack would suck more with a spool........ manual rack or not you have to be carefull in the turns and can't take tight turns with a spool...... on a DD you do NOT want even a mini spool... Drive a car with a manual rack and try and creep into a tight parking spot........ you will hate the manual rack before you hate the chirping rear tires...
I have a bmr k-member waiting to go in. My abs goes nuts because i have 15x4 26x6.5 front and 15x9 27x11.6 rear. So it will be off no mater what. Know tons of people just doing ABS delete with power brakes and they love it. Just seeing what more people running manual brakes think.
Im not talking about passing people....... Im talking about someone tht has a tire fall out of the back of their truck on the highway or even on a 35mph road and in a second you will run over it if you don't react...... try that wil manual brakes and power steering..... I allways stayed way back but you can't do that all the time with a DD.
You can still make u-turns, just not as tight as you can in a power steering car... like I said, you can't expect everything to be the same.
Those front wheels are not really skinies honestly....
Ditch the abs, its no big deal unless you have to stop in the snow (not an issue in FL) or have to make a hard stop in the rain.
You don't need a full spool most don't, you will notice how the manual steering sucks in turns before you notice the spool also sucks.
Like I siad, do a search because there is a ton of threads on people saying NO to manual brakes on a DD but it seems you have made up your mind so have at it.
Havn't converted to man brakes yet, but I would think everyone has there own tollorance when it comes to things like this. Best way would probley be to find a friends that will let you take it for a drive.
if you are ditching the abs, then there is no advantage imo. use you foot.
only thing i would be worried with is how large the bore on the stock brakes are compared to an aftermarket setup.
pistons being different size might throw the pedal feel off??
it will be a weekend car before you know it cut it up.
