Drag Racing Tech
Weighed My Pig of a Trans Am Today....
Old Aug 20, 2009 | 10:05 PM
rpmauto's Avatar
3750 with me, either i need to cut weight, or add power. I am going the power route. I want a pig to fly.
Old Aug 20, 2009 | 10:22 PM
TORCHD 02 TA's Avatar
Originally Posted by ls2 bait
ha! thats nothing. my turd weighs 3706 w/o me in it!
I thought you did some weight reduction on yours? why is your car so heavy?
Old Aug 20, 2009 | 10:23 PM
that is a good one
Old Aug 20, 2009 | 10:54 PM
SScam68's Avatar
Originally Posted by TORCHD 02 TA
nah i have been ok.. Just remove all interior everytime i go to the track and that is about it..
If i remove all the stuff that i mentioned in my first post, swap rims my car looses 175 lbs
Hahaha, see that's how it starts
Old Aug 20, 2009 | 10:56 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
The ol' white one was 3300 raceweight, I'm 200.
I'm hoping to get the black one down to 3150 with driver.
Old Aug 21, 2009 | 12:33 AM
promod1955's Avatar
The stock internal car i have is 3080 with me in it and i didn't cut a thing off the car. that was with stock brakes too. It had a pretty much full interior in it. Basicly you have to dissasemble the entire car, Figure out only the things you must need. Then figure out how to make them lighter. Should be 120lbs lighter when i get it finished...again.
Old Aug 21, 2009 | 12:37 AM
wtf did you do to make the original parts lighter
Old Aug 21, 2009 | 12:40 AM
promod1955's Avatar
magic. haha. You just got to get creative. Then things like the k-member etc. are replaced with chromoly pieces. I built a stainless x pipe exhaust and made a muffler, the whole deal only weighs 10 lbs.
Old Aug 21, 2009 | 03:15 AM
Driftunit's Avatar
hmm well whats some things you made lighter or modified? hole saw stuff?
Old Aug 21, 2009 | 07:02 AM
Nitroused383's Avatar
My SS with leather, 12 disc cd, monsoon system, 17x9 SLP ZR1 wheels, M6, LS7 clutch, and subframe connectors weighs 3550 with 1/2 tank of gas.
Old Aug 21, 2009 | 07:36 AM
promod1955's Avatar
a bunch of stuff I've remade out of chromoly tubing. got rid of the wipers and made some dzus in aluminum panels to cover the holes left in the cowl. Got rid of one of the horns and cut the bracket. I took the stock radio apart and put just the face of it Back in the car. no hole sawing. I hate the way that looks, even if it is covered up.
Removing weight is not easy nor cheap. What I've spent to lighten the car up, I could have built a killer engine. Thats just not the route I wanted to go with the car. One day if it gets a new engine, the car is already setup for it and should run pretty good with the weight its at.
Old Aug 21, 2009 | 01:24 PM
  #32
Driftunit's Avatar
wow thats some intense stuff lol
Old Aug 21, 2009 | 03:30 PM
  #33
TravisA's Avatar
Originally Posted by Rickys S/C Z28
man i was surprised how much my turd weighs with an 80 and a 8.8 with me in it (225) my car was 3742
Ricky,
Where did you weigh your car at?
Old Aug 21, 2009 | 03:39 PM
  #34
SScam68's Avatar
That's the truth. Some of the basic stuff (bolt off) is easy. When you start digging into it, it requires more work. The reduction that will set you apart from the rest of the pack will start costing you some $$$$$. There is about $3k in parts that I need to get my car to the 2700 range (2920lb right now). And that's before any cutting
Old Aug 21, 2009 | 04:18 PM
  #35
Reject's Avatar
yikes i would love to get mine in the low 3k
Old Aug 21, 2009 | 05:17 PM
  #36
01RedZ28's Avatar
Torchd where did you go to weigh your car i've been dying to see what mine comes in at since all the weight reduction.
Thanks
Old Aug 21, 2009 | 05:29 PM
  #37
bene's Avatar
Trunion King
That is why i hate camaros, from the factory they are like 200 lbs lighter
Yeah, those camaros do come out skinny.
Mine weighed like 3290, 3/4 tank of gas, chrome 18s all around and fully option Z28 automatic.
Don't know how much it weighs now with T56 and some suspension upgrades.
Old Aug 21, 2009 | 05:46 PM
  #38
Camaro396's Avatar
Take those heavy *** wheels off there!
Old Aug 21, 2009 | 06:42 PM
  #39
My 16x8 Alloys with my new M/T ET Street Radials weigh in at 48lbs.. TTMs weigh not that much more i bet...q
Old Aug 21, 2009 | 07:05 PM
  #40
Camaro396's Avatar
I was thinking more along the lines of static weight vs rotating mass. Each static lb converted to a rolling mass is like 3 lbs. Given my 8lb Alumastars vs 4xlb stock wheels, that's an awful lot when converted.
