672BBC Twin turbo O/L 10.5
#41
LS1Tech Sponsor
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
2016 Z07 Carbon
#43
Ok enough of this, let's just go ahead and tell everyone the truth.
![Angel](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_angel.gif)
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
-Dave
#44
THREE WORDS....
REE DICK ULOUS
awesome work... can't wait to see that monster.... methanol baby. compression and boost.... so you can have your cake and eat it too...![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
good luck with it man.
REE DICK ULOUS
#47
lift is less than an inch
This is really a motor Shawn's building for my little Corvette. It was suppose to be a big secret
but I can't just keep it secret any longer. Shawn now that the cats out the bag try and get it finished by the end of next week. I can't wait to get that monster between my frame rails!!!! ![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
-Dave
-Dave
sucks when you are to busy to work on your own stuff.The intake should be done in about 3 weeks,if i can light a fire under John's ***
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
#48
here are a couple more pics
fuel pump-flows 25 gallons per minute
![](http://i256.photobucket.com/albums/hh190/twinturboz28camaro/newpictures8-24-09001.jpg)
![](http://i256.photobucket.com/albums/hh190/twinturboz28camaro/newpictures8-24-09002.jpg)
keyway lifter
![](http://i256.photobucket.com/albums/hh190/twinturboz28camaro/newpictures8-24-09003.jpg)
![](http://i256.photobucket.com/albums/hh190/twinturboz28camaro/newpictures8-24-09004.jpg)
60mm cam compared to std bbc roller cam
![](http://i256.photobucket.com/albums/hh190/twinturboz28camaro/newpictures8-24-09006.jpg)
![](http://i256.photobucket.com/albums/hh190/twinturboz28camaro/newpictures8-24-09005.jpg)
triple valvespring compared to ls1 double spring
![](http://i256.photobucket.com/albums/hh190/twinturboz28camaro/newpictures8-24-09007.jpg)
wristpin compared to heavywall ls1 .927 wristpin
![](http://i256.photobucket.com/albums/hh190/twinturboz28camaro/newpictures8-24-09008.jpg)
![](http://i256.photobucket.com/albums/hh190/twinturboz28camaro/newpictures8-24-09010.jpg)
piston with coating
![](http://i256.photobucket.com/albums/hh190/twinturboz28camaro/newpictures8-24-09011.jpg)
![](http://i256.photobucket.com/albums/hh190/twinturboz28camaro/newpictures8-24-09012.jpg)
![](http://i256.photobucket.com/albums/hh190/twinturboz28camaro/newpictures8-24-09013.jpg)
![](http://i256.photobucket.com/albums/hh190/twinturboz28camaro/newpictures8-24-09014.jpg)
crankshaft-crower billet with olds main bearings and hemi rod pins,also has an 8 bolt crank flange-weighs 95lbs
keyway lifter
piston with coating
![](http://i256.photobucket.com/albums/hh190/twinturboz28camaro/newpictures8-24-09015.jpg)
#53
Race your car!
LOL. That fuel pump... 1500 GALLONS per hour. We're used to 2 255 litre per hour pumps being alot for comparison.
The wrist pins and whatnot, all that stuff is just nutty. I've seen the 1/2 shafts for cars that look smaller/less beefy then the wrist pins are![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Keep the pictures coming, it's great to see the ultra wild end of things to put just how simple a 9 or 8 second build really is in comparison to that.
#55
OWN3D BY MY PROF!
#56
#57
Race your car!
As we discussed with rotating assy weight, I was wondering at what point the same issues become relevant.... that's some heavy hardware going in the motor.
Sounds like a fiberglass front clip, and shifting the front suspension foreward a bit might be needed to balance it out some, unless that's against the rules/goal of the car.
#58
