Warm Air vs. Cold Air
My point is warmer IATs means car runs like shiit.
Someone back me up on this?
the point i was trying to make -DA is best to race in
In general, 12 and 11 second cars (this general speed range) will benefit from lower da every time. You start getting into 10 and single digit cars, ones that leave really hard, sometimes they will nto see the gains as much. If the suspension is adjusted accordingly and the track is there then yes they'll see every bit of the benefit like a slower car.
The DA is what determines what you'll run.
On my Camaro, it would run low 9.30's in great air & high 9.50's in hot sticky air.
There is definitely a huge difference in good & bad air.
Edit- NVM, yes.
Next time do not back the entire car in the waterbox. The front tires do not belong there. Just get the back ones wet, spin them over then move right to the edge of the box. Then do your burnout getting them smoky, then ease up on the brakes until the tires chirp. You will get a better 60' that way vs doing a burnout in water and then letting off it.
