what solid motor mounts for a PA k-member?
Heres what it looks like......
http://www.umiperformance.com/catalo...products_id=74
wonder if the 4 bolt pattern is the same on the block. The guy i talked to from PA was really beating around the bush on what to use. Or use the stock style upper xhell and run a bolt through the 2.
Your looking for LSx mount correct?
From your build I would wonder why not go with a plate.
and if push came to shove I am sure you have the skill to fab up what you needed
Hope that helps,
Ryan
https://ls1tech.com/forums/lsx-parts...iters-new.html
If you are stuck on the solid motor mount option there's a thread on here with pictures from a while ago. I remember 9sec93 posted some pictures.
