screwing radials
To be honest I don't think you need to run screws because with the radials you are running more air pressure which helps it seat to the rim. A bias tire runs less air, so it does not seat to the rim as well.
It most definitely does move, I can live with it seeing they are tubeless.
The way the 'fast' guys told me to do it wa to put a light coat on both the tire and wheel, let it dry for a minute and then mount it. Thats what I did. I may knurl the inner surface of the wheel to get a little more bite.
I dont think it moves that bad for a 3400 lb car that 60's 1.29-1.30, beadlocks are the only thing that would stop it 100%, or screws but the bead bundle is different on radials and they really dont recommend screws.
