anybody pullin wheelies on 26 inch slicks?
No front sway bar on the street is really no big deal. I took it off and added strange SA shocks and 300lbs springs. When the shocks are set on a firmer setting I think the car handles better than it did when it had a sway bar. I still haven’t put the stock bar back on just to see how it is with the new coilovers. The stock shocks blow that’s for sure
Internet Mechanic
I have no front sway bar, the car is sloppy but it does not bother me enough to care. When the UMI rear drag bar goes on, it should tighten everything up nicely. I still have SFC's to go on which will be another major part.
Pulling the front sway for the 1/4 mile is one of the most important things you can do.
Look at the driver's side rear quarter panel does it have dimples down the top just in front of the rear tire? Good luck with your new parts that you have ordered I am sure it is going to help!
N2
Internet Mechanic
Man you really need to consider installing the SFC's first. If you put the drag bar on your car first it is going to stay level in the back and the front is still going to want to twist like in your photo causing more strain on the body without the SFC's.
N2
N2
I still have a busted Tru trac but I will deal with that later.
No dimples yet as I have been good about not racing her
ok guys so if i take my front sway bar out how fast can i take a corner with the stock SS wheels and tires? if you take a corner to fast will it break parts or throw your alignment out?
obviously it won't handle as good as it would with it but what i am concerned about is any potential damage to my car parts. i could care less about the handling characteristics......
