Going to the track for the 1st time...
Whatever you do, don't just side-step the clutch because once the tires are shocked your not going to get any traction at all..
Make sure to only have a 1/4 tank of gas, and let the car cool atleast 30 min between runs if you want optimal times..
GOOD LUCK!!
GOOD LUCK!!
oh and once you go it is extremely addicting so consider yourself warned! lol
The right way is 5k and let if fly but considering where the car is that, it is not an option. You could ride the clutch a little but thats a sure fire way to ruin that.
Air the tires down a little, see if you can add some to the fronts to make them hard. Clean off the rear tires, do not go through the water. Bump the revs to 3ish k and quickly let off the clutch and roll in the throttle. Go WOT after the 60 foot. Then its about quick shifting.
In the end its all about.
Practice
Practice
Practice!
