Brass carb idle feed restrictors
Anybody know where to get BRASS set screws? I want to change out my idle feed restrictors, air bleeds, etc. at will without spending a few hundred dollars on new metering blocks or an expensive HP carb. I can get hardened steel set screws but they're next to impossible to drill. The replacement bleeds from Holley, BG, AED, etc. won't work with the stock metering blocks without more machining that I didn't want to get into at this time.
