Instant center AS and IC ht. numbers
#41
what class do you run? can't say I've noticed your car at dinwiddie or MIR. I take it your name is Mike?
Mike, I may be 100% wrong. I've been wrong before. I'm going to be wrong again. Its a part of life. Im just sharing with others what I've learned and found what works. Thats what this place is about right? To share info and help each other? You were looking for some help, I tried to help by understanding how your going about measuring your IC. Your giving people a bunch of numbers in the first post and no way of saying how you came up with the numbers? What good is a bunch of numbers if I cant reverse engineer it and figure out where your suspension points are. Why can't I get you to understand this? Your as hard headed as my girlfriend. You guys would be a perfect match.
So lets start over..... Talk to me like I know nothing about a torque arm. Whats this magic formula you have to come up with those numbers? I'm trying to help you Mike. I knocked 19 thousandths off a customers car last week in an 1/8th mile. I may be able to help you out too if you give me something I can work with. I charge double the amount for people with attitudes BTW.
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
#42
I could only get the first video to work. I really didn't see anything to get me excited.
#43
So lets start over..... Talk to me like I know nothing about a torque arm. Whats this magic formula you have to come up with those numbers? I'm trying to help you Mike. I knocked 19 thousandths off a customers car last week in an 1/8th mile. I may be able to help you out too if you give me something I can work with. I charge double the amount for people with attitudes BTW.![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
If what you're saying is true, then why do several manufactures offer torque arms with adjustable vertical settings for the front? If what you're saying is true, then adjusting the front of the torque arm up, or down, wouldn't have any effect at all. Correct? Here's an example of what I'm talking about. BTW, I have no idea what to believe at this point and I'm just trying to learn like anyone else.
My car is lowered almost 2" and it has a Spohn tunnel mounted torque arm. I fabricated some new rotator plates for the front so that I could move the front of my t/a upward toward the tunnel. My thought process was that since the car is lowered, the front of the t/a needs to be raised back up. I did this because after reviewing my videos in slow motion, the tires were being hit really hard at first (driving them downward), then unloading almost immediately. After raising the t/a up about 1.5", and after reviewing more video, the tires weren't being hit nearly as hard and the launches were more controllable. Since then, I've installed Strange drag shocks in the front and now I've moved the t/a back down one hole (about .75"), and set the rear (comp engineering) shocks on full firm on compression (70/30). I'm hoping to get the tires to plant hard again (but not AS hard as previous) and that the added front drag shocks, and stiffer compression on the rear shocks will help keep the tires planted longer.
BTW, this is a 6sp car and I'm currently launching around 5k rpm and still spinning my way to 1.66 - 1.70 60' times. Would love to hit mid 1.5's.
Mike
#45
I see you changed shocks later on... but this sounds like a shock valving issue.
#47
LS1Tech Sponsor
I see this a lot as well and I'm not sure why they do that. Selling tool maybe? I played with that adjustment on a wolfe torque arm and it made 0 difference in how the car left. I am going to look into this further with a faster car soon though and see if I can get any change in it. I think I may see a slight change but not because its making the IC longer/shorter.Some killer hardcore road course cars with torque arms I have seen dont have an adjustment area there. Nor did the pro stock car if I recall correctly.
The adjustment holes in our arm isnt just a selling tool. We have been building this arm since early 95( we have made upgrades and revisions as we learned). I have found after 1000s of passes on t/a equipped cars that this suspension isnt like a 3/4 link or a ladder bar. 90% of the info about this suspension is for road racing cars so you throw that out the window.
If you move the front of the t/a up in the car then it will hit the tire quickly but it will unload the tire faster. Lowering the arm will pick up more weight and keep the tire planted longer. I dont get into all the math formulas for this style suspension because the theory isnt right.
#48
Race your car!
[QUOTE=MADMAN;12339721] Lowering the arm will pick up more weight and keep the tire planted longer. QUOTE]
No wonder I put my car on the bumper last year... I lowered the frotn of my bmr tq arm down on the bmr th400 crossmemebr with relocation.
N/a the car liked it, it stopped spinning 5 feet after I left when I did it, so I lowered it some more for the start of last season figuring that if it helped n/a I would need to lower it more to help get the car to stay planted.
Probably went too low with it (3rd hole from bottom, n/a I ran it 1 hole higher)
Limiters did stop it from standing up, maybe try tightening the front end up on the limiters (went 1 hole looser then you suggested after trying them where you suggested starting) and lowering the tq arm down another hole, unless it starts spinning at the hit, in that case raise the tq arm back up.
Make sense?
(I'll pick your brain Brian when I order the racecraft front end, hopefully end of this month)
Make sense?
#56
LS1Tech Sponsor
Madman's at the Shootout in Memphis, if you're up there you should swing by and chat with him.
__________________
"Cars don't squat, girls do."
Avoid nutswingers: for genuine Madman products, buy only from authorized dealers - http://madmanandcoracing.com/dealers.htm
Authorized dealer for AFCO, Mickey Thompson, and Strange Engineering
![](https://ls1tech.com/forums/signaturepics/sigpic139249_1.gif)
