Burkhart Rear Bumper Support Pics
#62
Look good so far.
Any pictures of the front and rear installed on a 4th Gen Camaro.
(The rear with the chute mount option.)
That's the one I need/want.
Also are these CM or mild steel?
#64
CM weighs more than mild steel correct? Depending on the gauging u used, but for the fronts on the camaros, does it use the same one as the one above installed?
HOw much does the front weight it looks to be about 14lbs?
Which is only a mere 10 lbs savings, but it save you a bumper from cracking!!!!
