Drag Racing Tech
Best Way to Drop Ride Height?
Old Oct 14, 2009 | 11:11 AM
LS1Silverado05's Avatar
Default Best Way to Drop Ride Height?
What is the best way to get a moderate drop in ride height without brutally sacrificing weight transfer? Is cutting the springs a viable option?
Old Oct 14, 2009 | 01:33 PM
JL ws-6's Avatar
Race your car!
Front is easy, go with a qa1 shock or the like, and just adjust the preload.
The rear, you can pull the spring isolaters and put some hose over the spring, that will get ya an inch or so.
If you have access to a big table sander, you can take the rear springs and "surface" them, turning them as you do it on both sides and pull about another 3/4 of an inch off that way as well. Pita, but it works good and the springs sit on the car and the rear good afterwards.
Old Oct 14, 2009 | 03:48 PM
MelScrilla's Avatar
to still transfer weight dont you have to drop the front and rear evenly?
And if you run big radials you have to watch out for rubbing.
Old Oct 14, 2009 | 08:27 PM
JL ws-6's Avatar
Race your car!
Depends where the weight is and what the car needs, sometimes ya may have to drop the rear more then the front.
Old Oct 15, 2009 | 05:10 PM
358chevycamaro's Avatar
And sometimes you have to drop it a good bit more in the front, like in my situation this past year.
Old Oct 15, 2009 | 10:18 PM
Thanks for the input guys...
Well, the thing here is I like to run the car with the 17" ZR1s mostly and keep the sleeper look going, but when I DO go to the track I dont want to be stiff as a board and just spin either... Its not a full on drag car by any means, just figured you guys could give the best advice in this area... Thanks!
Old Oct 16, 2009 | 01:38 AM
daniel6718's Avatar
if the back is squatting your doing it wrong...the only thing you want moving is the front comming up slightly...dont worry about weight transfer at all...just get good suspension pieces
Old Oct 16, 2009 | 05:40 AM
95wannabe's Avatar
is this correct ?
you wouldn't want the rear of the car to be able to sqat down ? ie ...soft springs ?
Old Oct 16, 2009 | 06:32 AM
JL ws-6's Avatar
Race your car!
The rear shouldn't move any more then it absolutely has to in order to maintain traction. generally, squatting is lost energy... when on an absolutely terrible track, you may need it to squat to get/maintain traction, but as a general rule, the rear should be seperating from the body leaving the line, planting the tire, not the back of the car dropping to get the weight on them.
Old Oct 16, 2009 | 08:48 AM
95wannabe's Avatar
So, I wonder if the springs in my car, originally a v6 car, are softer than what came in a LT1 car?
Ive read of guys cutting a coil off the bottom of a stock spring to lower the car ... is this a good or bad idea as far as traction goes?
Old Oct 16, 2009 | 09:59 AM
JL ws-6's Avatar
Race your car!
I don't like doing that, the spring doesn't sit on the housing right, it changes the spring rate (stiffer because each coil now has to move more for the same amount of travel)
Adjustable spring perches, and a regular coil spring is the right way to go about it.
