Drag Racing Tech
passing tech with pro star lugs?
Old Oct 26, 2009 | 11:22 PM
chrismcdaniel's Avatar
Default passing tech with pro star lugs?
OK, so with the mosser axles on my 9', i have 3in long wheels studs. With my 15x10 prostar, and my 5/16th spacers, there is only about 3/4 inch of threads remaining, and those will not come all the way through a set of open end, long shank lugs nuts. Now, if i remove the spacers, and beat the **** out of my fender well, there is still not gong to be enough stud with the prostars.
whats the trick?
i could go with the 4" 5/8ths studs, but i dont think the long shank lugs will work with them.
I did cut the bump stop brakets out, but the tire still rubs pretty bad even with that done with no spacer.
Old Oct 27, 2009 | 08:53 AM
jmm98LS1's Avatar
Mine don't stick out past the lugs and I've never had problems through tech......is that a rule?
Old Oct 27, 2009 | 09:24 AM
Bitemark46's Avatar
The rule is that the studs have to protrude into the hex portion of the lugnut equal to the diameter of the stud. So for example if the stud is 3/8" diameter it has to go into the hex portion at least that far. Hope this helps.
-Mark
Old Oct 27, 2009 | 09:37 AM
5.3LJimmy's Avatar
You can buy ARP studs that are long enough that still use the same lugs. I believe mine are 1/2"x3 1/2" long and stick out a good bit past the open end. I'm running the 15"x10" prostar with 28"X10.5" ET drags without a spacer and Strange brakes. I cut out some of the bump stop and took a big hammer to whatever else was in the way.
Old Oct 27, 2009 | 10:22 AM
James Montigny's Avatar
That's much better than having to protude... which would be tough considering all of my Prostar nuts are closed-ended.
Old Oct 27, 2009 | 10:30 AM
tim99ws6's Avatar
Not gonna pass tech at any legitimate racing sanction. Probably never have a problem at any locally ran tracks though!
Old Oct 27, 2009 | 10:41 AM
Because of the closed lugs?
I'm all for being safe (and legal), I just want to know what it is that I need to do.
If the studs that came with this S60 are too short, I'd rather get them upgraded than have one break on me.
(I don't run spacers on the rear)
http://i38.photobucket.com/albums/e1...awk/img022.jpg
Old Oct 27, 2009 | 10:52 AM
tim99ws6's Avatar
yep,
I know at the LSx shootout not this year but last year they made me remove a lug....only to show i DID have ARP studs...but they weren't long enough like the OP said.
I went with stock diamater 3.5" long ones on all four corners now.
Old Oct 27, 2009 | 03:52 PM
Bitemark46's Avatar
Correct. They want to see the stud through the lugnut. So closed ended may not pass tech for a sanctioned event but for a local TnT night its probably ok.
Sorry I used the wrong word when I said protrude. But yes they have to go at least half way into the hex portion.
-Mark
Old Oct 27, 2009 | 04:36 PM
Ok, cool so ARP makes some 3.5's ill have to look for some, anyone have a link to the screw in ones?
Old Oct 27, 2009 | 08:14 PM
5.3LJimmy's Avatar
Thunder racing has the metric studs(stock size) in 3.25" or 1/2"x3.5"(may require new lug nuts depending on what you have). http://www.thunderracing.com/catalog...vid=3&pcid=148
Old Oct 27, 2009 | 09:43 PM
BadBandit69's Avatar
I had prostars with 5/16 spacers and 3.25" arp studs and they were long enough to be into the hex the diameter of the stud. My track doesn't check but i wanted to be safe so i just did it.
And btw 5/8 studs you don't use shank style lugs. The prostars are set up for 5/8 you just put a washer and a big nut on that doesn't go into the hole. The shank style fills that gap for the 5/8 hole with the stock 1/2" stud. But 5/8" is for "race cars" in my eyes cause there can't be many street wheels with 5/8 holes. So your stuck with drag wheels.
Old Oct 27, 2009 | 11:01 PM
01z's Avatar
01z
yep,
have a PN for those?
Old Oct 28, 2009 | 08:40 AM
tim99ws6's Avatar
12x1.5 right?
Off Summitt they are "ARP 100-7713"
Old Oct 29, 2009 | 12:55 PM
1BADAIR's Avatar
if you have closed end they may make you remove one to check.
basically the stud has to stick out 12mm past the washer.
or 1/2 for 1/2 studs
