Leavin' in a 6-speed
I've got enough passes under my belt at this point that I really feel like a pansy asking questions like this. I'm going to ask anyway, however. I'm looking for some advice on how to leave the line in my T/A. Let me give you just a touch of history so you understand my position.
My car was, for a long time, a 400RWHP cam-only car. T-56, obviously, with a Dana60 and 4.10 gears. With that setup and some 12" slicks, I would usually 60' in the 1.7s. Traction was never an issue. It always seemed like power was lacking to get the 60' to improve.
Initially, this setup was using a Textralia single disk clutch. I left by revving her up to 6k or so and dropping the clutch. Rather than holding the RPMs up, I would stab the gas on the second yellow and just dump the clutch when it got where I wanted it. I was pretty good at timing it.
Later, I switched to a McLeod RXT twin disk, and let me tell you that this is one badass clutch. I started out bogging it a great deal while letting the clutch out very quickly, but not just dropping it. Finally, I got frustrated enough and mustered enough nerve to drop the hammer on it from 6.5k+. I revved it up to no less than 6500 and dropped the clutch and the result was worse than embarassing. The car straight stalled. I was sure I broke something because I heard these banging sounds that I was sure were pistons and rods falling into the oil pan. Turns out, it was just some afterburn in the exhaust. I started the car up and made my pass of shame.
Fast forward a year (and a lot of headaches). The car is now Procharged and puts out more like 625RWHP. I've only had it out to the track once in this state, and I cut a 1.58 60' slipping the clutch a BUNCH and just being real gentle with it. Needless to say, I'm still pretty gun shy with dropping the hammer.
Today I was looking around in the multimedia forum at 6-speed passes in some fairly fast cars. Most of them seemed to drop the clutch. They would hold the RPMs up around 6k and (apparently) stab the gas and drop the clutch. Rather than what I experienced, they seem to get maybe a touch of tire slippage, a great deal of weight transfer, a loss of maybe 3k RPMs, and ultimately a damn nice leave.
Does anyone have any advice for me on this? Should I not drop the clutch the way I did in the past? Is my clutch and tire combo just too much for the power the motor put out (when it was 400RWHP)? Should I try again now that I have more power? Is there something I'm missing?
Advice and/or words of encouragement accepted. Thanks in advance.
EDIT: Here is a video of the pass with the 1.57 60'. My friend's slow 'stang is drowning my car out, so you can't hear much, but you can see how gently the weight transfers...
Click here for video
two of my buddies in there 6 speed cars just cut 1.51(ws6-srt)d1sc and 1.53 turbo camaro(550ish hp) I think they did a fast let out at high rpm 6,000ish.
Drop the hammer and see where she leaves you.
I think that with the traction I have in this car, I'm inclined to just work my way up to dropping the hammer. I think the traction and clutch in this setup are enough to either break the drivetrain or stall the car on a dump. I think slippage is going to be necessary, but I'll work my way up leaving harder each time until it's more apparent what will happen on a dump.
if it bogs, raise the rpm, add a 1/2 lb of air to the tire.
When it finally starts spinning, start taking the air out of the tires.
My advice, put a good tire back there, drop the clutch and see what the suspension wants/needs afterward. It's much easier to deal with spinning the tires and making suspension adjustments then it is to glaze a clutch disk.
Mike
http://www.youtube.com/watch?v=7c9pIsyWa30
http://www.youtube.com/watch?v=M6A4ECmz4O0
I just ordered a 2 step to help this. What do you guys think about what happened to me when I stalled the car? I mean, for crying out loud 6500+RPM at WOT on a 400RWHP motor, and the drivetrain stopped it dead in its tracks. The car might've moved a foot, and the engine acted as though it has siezed. That definitely shattered the nerve I once had launching this car.
Just air the tires up about 3 or 4 psi more then you think you need them, and get a 2 step. Then you put your foot to the floor on the 2 step, when you let go it goes back to the regular limiter...
This way you can try leaving at 5000, if it bogs, leave at 5200, bogs try 5400, bogs try 5600 etc.etc... and go until it spins, then take 1/2 a lb out of the tires until it starts to show a sign of bogging again, then up the rpm 100 more and continue until it's right.
Start at 5400 with 16 psi in the tires and see what happens, you'll get it right and the car will fly.
Definitely get a 15 inch rim and a bias ply tire on the car, at your power level trying to do it on anything else with the stick in the car, isn't gonna work too well. If you had an auto, it would be a differtn story you could leave a 17 inch rim on it and get it to leave in the 1.5's, but the stick, really makes the 15 inch tire sidewall a nessassary item to have.
I also agree with AChotrod. If you get a 2-step you'll be able to launch at WOT with will keep the rpms up and you'll be less likely to hook and bog. Just do what I did set it at 5500 and work your way up. I ran my PB launching on the 2-step at 5800. Unfortunately I had to leave that day to attend my niece's and nephew's 1st b-day party so I did get a chance to bump up the 2-step. I'm going to the track this weekend and I'm starting the 2-step at 6000 and working my way up.
Btw, I'm running Lingenfelter's LNC-002 2-step which includes a timing retard function for boost and N2O applications.
this was my first time on 28's
http://www.youtube.com/watch?v=cM32HyHTO6I
