Cam or stall?
PERSONALLY, I'd do a cam since you have something in there and its a quality 'verter BUT you should look at something 3500-4500 and you will really see a diff in performance.
Has the car been tuned? has the TQ management been decreased or removed?
Personally I'd run at 4000 stall if I was looking for a strong balance of strip and street performance. A true 3000 stall is decent, but it's pretty small and it will seem ever smaller if you go to a big cam. How much cam you want to run 224/224 - 232/24x? Where in that range? Typically a 22x/22x cam is pretty mild, would work well with a smaller converter. A bigger 23x/24x would work better with a 4000-4500 stall.
232/236 with a 111+4, or something like that and you should be good.
You can always have it restalled to whatever speed you need.
no need to rush the cam install it is a good chunk of change...
