Drag Racing Tech
Eagle Crank GMPP Single Plane Intake
Old Dec 10, 2003 | 07:27 AM
Mr. B's Avatar
Default Eagle Crank GMPP Single Plane Intake
Bret took these pics of the Eagle Crank & GMPP Single Plane Intake:
Old Dec 10, 2003 | 07:37 AM
Reckless's Avatar
Super Moderator
Love that first picture The other two are cool also
Old Dec 10, 2003 | 07:48 AM
Mr. B's Avatar
How about this one..
Old Dec 10, 2003 | 08:11 AM
Red01Chevy's Avatar
was that at the thunder shootout?
Old Dec 10, 2003 | 08:12 AM
RyanJ's Avatar
SSU Moderator
shut your door!! just kidding.
that single plane looks cool. not that i'd do it...but i'd like to see a comparison on a 422 or something...
Old Dec 10, 2003 | 08:51 AM
Mr. B's Avatar
Yup.. great event!
Old Dec 10, 2003 | 08:58 AM
Reckless's Avatar
Super Moderator
Hey! That's the first good pic I have seen from that event Thanks man! My door doesn't always close all the way. I think the bar padding is in the way.
Old Dec 10, 2003 | 02:08 PM
Vents's Avatar
ok, so who's gonna be the first to retrofit this carb style intake to 4bbl TB EFI? i wanna see that w/ some "stage 3" LS6 heads and a solid roller.
Old Dec 10, 2003 | 04:08 PM
InconFormula's Avatar
Is that an ls1 rotating assembley from eagle? If so how much$ and where did you get it.
Old Dec 10, 2003 | 04:23 PM
Loudmouth LS1's Avatar
Yeah, I'd love to know that too!
Old Dec 11, 2003 | 07:24 PM
Skelton's Avatar
Now I can build a 67-69 camaro or early nova and run a all aluminum 427 with a carb and nitrous. I can't wait!!!!!!!!!!!!!!
Old Dec 11, 2003 | 08:18 PM
GeorgeC's Avatar
It's still not going to be "easy" to run a carb on an LS1, since you've still got to have some pretty elaborate electronics for the ignition.
I would think at least a crank trigger and something like the FAST e-dist box...
Old Dec 11, 2003 | 09:44 PM
Billy the Great's Avatar
i thought i have seen that gmpp has figured out a way to run a gear driven dist.
Old Dec 11, 2003 | 10:07 PM
427's Avatar
427
The manifold is from Wegner. He also has a front cover with fuel pump and distributor drive with a water pump that clears it all and has clockwise rotation.GMPP sells only the intake. Edelbrock also has a carb intake and MSD has a simple stand alone box that runs the coils with a built in timing curve.
The gen 3 is getting some cool aftermarket parts....
Kurt
Old Dec 11, 2003 | 10:16 PM
taqwache's Avatar
I think MSD already came out with a module that you plug in to the origanal crank sensor, cam sensor, and coil packs. this would be cool. but i would drill it to fit my injectors and just run a TB on top of it to keep it injected. can anyone flow this intake next to a LS6. i am curious.
Old Dec 12, 2003 | 04:01 PM
RobZ's Avatar
Anybody know what the cost on the Eagle crank is going to be?It looks more like a complete kit.I hope it comes out pretty soon.
Old Dec 12, 2003 | 06:29 PM
Squintz Palladoris's Avatar
Fab a bracket and timing chain cover and pulley for a sbc front mount/belt driven distributor with a crank trigger. lmao
I would love to see an efi setup with this intake. The gears are turning in my little brain
Brad
