10.5 all motor
3500lb race weight with 260lb driver
M6 with 4.11 in the rear.
Should be decent in the 60's old set up was good for 1.6's, low 1.5's are there.
Motor and power need for this which one?
346, with good 5.3L heads, PRC maybe decent cam 230 range, 1 7/8 kooks with true duals, Fast 90/90
383, with same set up but a bigger cam 250 range, Fast 90/90
402 with bigger heads LS6 and bigger cam, Fast 90/90
402 with TEA heads LQ9 style(350 range for air) Fast 102/102 set up with a big cam
418 with the same top half as the 402.
What motor option will get me there?
Will the 383 do it? Should I stake that with LQ9 heads with 102/102. I want to do it right.
Old set up was 3500lb race weith 11.7 @ 117 with a 1.6 60ft time. 346 with patriot 5.3's, 224/224 cam, 1 3/4 headers true duals, 4.11 and LS1 intake. Guesing it was about 400RWHP. They dont run like they do in texas.
That should get you into the mid 10's.
You can get there with a 383 combo and make the car hook better with 50lbs off the nose of the car. 383 with some TFS 225's and a FAST 92 shoud get it done.
We built a buddies car, 347 with a TFS as cast, Fast 92, Bauer cam it made 455 to the wheels, ran 121 mph at full weight.
SO is the raceweight 3500 or 3760?
What do I need to do to the suspsion? Torque are, lca, and panhard rod. Good tires on 15in rim I should be okay?
-1.47-1.48 60's all day and night.
-97.5-98.5 mph depending on the weather.
-7.5" 10 bolt w/ 4.10 gear.
-th350 with a Fuddle 3600 nitrous converter just off the foot brake.
-Stock torque arm, all non-adj suspension, lca relocation brackets, CE 3 way shocks, Strange SA struts w/ 275lbs springs.
-Livernois St. 2 heads, custom grind Futral n20 cam, HS rockers, Fast 90/90, Probe pistons, Scat H-beam rods, factory crank, TSP oil pump, ARP studs throughout, SLP headers, BLUECAT tune.
If you wanna know anything else, just ask. Weight reduction will be be your best friend if you want to keep this as cheap as possible!
Going with the 402 or 418 with the LQ9 heads and fast 102/102. The heads flow 350 ish and with a big can 550 to wheels shouldnt be to big of a problem.
My old Z went 10.7 on a 1.5 @ 3300 raceweight, I'd want at least 50 more cubes on top of the old 347 cid to hit mid 10's.
