Drag Racing Tech
12 bolt power?
Old Dec 4, 2009 | 01:47 AM
T2SLS1's Avatar
Default 12 bolt power?
Any one running a turbo car with a 12 bolt making over 1000 rwhp? I will being running a spool with 35 spline axles.. power glide trans...
Old Dec 8, 2009 | 07:02 PM
Ed Wright's Avatar
9-Second Club
Surely not.
Old Dec 8, 2009 | 08:35 PM
6techniques's Avatar
Im quite sure there a a few...maybe lol. Check the FI and N2O areas. Im sure something will turn up for you.
Old Dec 9, 2009 | 07:49 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Like said, check the FI section.
What I will say its not about the HP as much, but rather the Force applied to the rear, and race weight will factor in greatly too this. I have seen a spooled 12 bolt puke the gears with out too much effort. A sponsor in the Eastern members forum did one in recently but I think it was on motor or motor/nitrous.(i forget)
I managed to break a tru track making 384 rwhp but a heavy race weight. It puts more stress on the parts.
I would like to see you try, I bet there are tricks to getting the car leave good (1.4x or quicker 60') and making 1000 hp and letting the rear live. I am thinking 2 or 3 step systems or going right to a BS3 deal.
Keep us posted!
Old Dec 12, 2009 | 10:51 AM
WHITE DEVIL's Avatar
on my 35 splined 12 bolt at 3440lbs making 750rwhp on nitrous i went a 1.31 60ft and never hurt a thing, mine has 5/8 studs, 35 spline, spool, Micronited gear set and i check them before, half way and at the end of the season.
Old Dec 12, 2009 | 04:31 PM
NHRATA01's Avatar
Trans brake or no? Most auto cars are easier on the rear - you have guys in the 11s and 10s on the 10 bolt. As long as your not shocking it something fierce I think you will be OK, especially with a spool.
Old Dec 13, 2009 | 09:12 PM
silverz28camaro's Avatar
I don't think you will be hurting it to bad with a glide. those 35 spline and spool are going to be tough. I think the only weak point would be the pinion gear if you went steaper then 4.56 gears. if you were to run a 3.73 or example the pinion is bigger and stronger, but either way I think it will hold.
There are a few threads about people running turbo'ed autos on the 10 bolt in the low 10's. a glide will be much easier yet on the axle vs. even a th350, no super low first, and no 1-2 shift shock.<----I say that becasue a glide is more like a 2-3 shift....
Old Dec 16, 2009 | 07:11 AM
southerntp's Avatar
Im running a moser 12 bolt with 35 spline axles. Race weight is 3275lbs. Motor makes 840 hp on motor plus a 500 shot of nitrous. Ran a best ET of 5.32 @ 132.6 mph with a 1.22 60ft. So far everything seems to be holding up just fine.
Old Dec 16, 2009 | 11:19 AM
AgFormula02's Avatar
12 bolt, spool, 35 spline axles. 1.24 60 foot times. No issues.
Old Dec 16, 2009 | 10:50 PM
mrdragster1970's Avatar
6 & 8 Second Club
12 bolt, 600 inches, brake, 3300 lbs and still going strong.
